SET amp owners thread
Clarity and detail of monitors with the weight and warmth of much bigger speakers. Must be positioned in corners in my experience.
Did you have a chance to hear Eufrodites, which are the smaller brother of these? I would be able to put mine close to corners (I have Odeon fully horn loaded speakers now that also need corners for bass reinforcement). Given the mid and tweeter are the same, just fewer woofers and obviously smaller cabinet, would you say they are pretty close or is there a huge gap in performance with Agalame?
Reactions: Klonk
can you tell I love SETS? 3 very different sounding SETs
impressive setup. Can you tell us what the amps are? Also, what are you doing for your deep bass because I guess the midbass horn goes to what? 100 hz or so?
Reactions: Dimfer
are those Sierra brooks horns
Sort of.. Victor Sierra of Sierra Brooks went solo and was doing very little speakers for a few friends to take care of their family business.. I think that’s about to change and he will be doing more audio again. chances are you will see more of his creations here at WBF as he is in contact with a respected WBF member ;)
Reactions: christoph
what are the drivers in yours?
respected WBF member is quite an Oxymoron
Reactions: jeff1225
Radian 950, with Duelund X over parts and wiring
with or without beryllium?
what about for the lower conical horn and for the tweeter
I have never heard the Eufrodites. I don’t know. Jeff Catalano will tell you how they compare. I’m not familiar with Eufrodites drivers, but the Agalme that I have use a DX65. I don’t think Tommy uses those anymore.
The Eufrodite uses the same driver for the mid, tweeter and woofers… just less of them in a smaller cabinet…at least the version I am interested in.
Current Eufrodites (and Aristotles, when configured) use the PM65 driver.
In the picture you can see my version uses 16 Beyma 8BR40 drivers in push pull configuration per speaker! I think that’s twice as much as the current Algame. I love his approach. Maybe he figured out how to do more with less. A6A16AF1-5CBF-4389-9B35-169076EA5F45.jpeg
In the picture you can see my version uses 16 Beyma 8BR40 drivers in push pull configuration per speaker! I think that’s twice as much as the current Algame. I love his approach. Maybe he figured out how to do more with less. View attachment 104768
The first Ellipse version of Eufrodite used 8 per speaker in push pull configuration…if I had space I would consider the bigger ones.
aluminum, because he finds it more musical
the tweets and the driver for the conical horn are Pro audio drivers similar to what OMA is doing.. Victor is known to dissect and modify drivers to fit his needs, so I am not sure if the drivers are off the shelf or somewhat modified.
He is one of the brains behind Kanzen
Reactions: morricab
Your system sounds most interesting Dimfer … I for one would love to hear a couple of audio vids , iphone etc , if you have time .
Two videos for you…Two for me
