The Amare Musica monos it turns out are significantly different from the Entropy Diamond in that they are tube rectified and they use silver wire output transformers...and different output tubes (300BXLS vs. 1605). I have no doubt they are quite superior to the Entropy Diamond, which as I noted, was a disappointment.As far as Crossfire III is concerned I heavily upgraded mine a few years ago , installed red NOS RCA tubes in pre section and KR 5u4g rectifier.
The power tubes have around 6000 h but still in good shape.
I use it in winter month, in the summer it is replaced by upgraded hybrid Circle Labs A100 integrated.
Both are perfect match for Trio LE 26.
A few years ago I tried Amare Musica monos plus pre with AG Duo Omega I had under this time, it was the best amplification for Duos I auditioned at home but only marginally better than Crossfire III. Finally I did not change Ayon, it’s a keeper for me.
I had also two Amplifon in the past ( WT 30II and WT 40II with PS 5.1 )but we agreed with Andrzej Piwowarczyk that it is not the best option for Trios.
The other Amplifon amps you mention are push/pull and not SET. Give the SET 42 SE a try as you are in Poland and should be able to demo one. I think it is significantly better than the Crossfire III. I had upgraded mine with NOS input tubes, an Ayon (EML) 5U4G and eventually replaced the 6N30P driver tubes with 6N6P tubes (helped the tone quite a bit).
