I'm adding the KR Kronzilla SX to my list of amplifiers under consideration.I'm also intrigued by the Line Magnetic LM-503PA monoblocks.
I like the KR 1610 tube, but have found it difficult to reliably get spare sets. There is only one manufacturer of the tube. When they are gone, so is the amp.I'm adding the KR Kronzilla SX to my list of amplifiers under consideration.
A Line Magnetic Lm508ia (with either a Microzotl preamp or Shindo pre) into Pureaudioproject Pap horns or Harbeth 40.2s but not Magnepan 20.7s, well not yet at any rate... indecision is clearly a strong point here. I may yet modify the Pap horns, I would love to maybe modify the 20.7s with neodymium magnets, I wouldn’t change a thing on the Harbeth 40.2s...
PAP trio 15 hornI have done loads to my horns. The best 2 mods are remote mount the crossover and use good wire to lace the drivers to the crossover. The second is I put my speakers on 50 lb blocks of engineered laminate wood, 9 inch tall. I put compressed insulation board under the block to protect my floor's. Holy cow. The bass is far far better. The horn more inline with the ear. I think reflection off the floor reduced. Putting them on the blocks was a big improvement. Cables and remote crossover removed all the fatigue.
I still wonder about a better horn driver.
I’m just very happy with the paps now, don’t want to spoil the magic. So I will play at another horn but use the Paps as they are as my benchmark. External crossover on the paps was also a really great move for me. Great to hear you are enjoying yours.I have done loads to my horns. The best 2 mods are remote mount the crossover and use good wire to lace the drivers to the crossover. The second is I put my speakers on 50 lb blocks of engineered laminate wood, 9 inch tall. I put compressed insulation board under the block to protect my floor's. Holy cow. The bass is far far better. The horn more inline with the ear. I think reflection off the floor reduced. Putting them on the blocks was a big improvement. Cables and remote crossover removed all the fatigue.
I've made some inquiries and the Kronzilla SX is, unfortunately, beyond my budget. I'm going to look into the Aries Cerat Genus stereo amplifier.I'm adding the KR Kronzilla SX to my list of amplifiers under consideration.
My speakers are 98 db/m, pretty efficient. I have easily run them with the LM 219ia. What SETs should I be looking at? The LM 845 monos look interesting, Kronzilla SX, Allnic 311M, etc. I haven’t been a fan of 300b, at least ones I have found. Someday I may go horns, the hORNS Universum look interesting, I will try and find a pair to audition.
The LM219 was 22 watts. Thought it was good, but lacked that last little bit off bass that my EAR amps have. I now run subs, so bass isn't an issue. I have heard of people successfully running my speakers with 10 wpc. Btw, Birmingham, in the US or elsewhere?
How does a 2A3 - 4 to 6 watt Whammerdyne amp make good bass with my Pure Audio Project trio 15 horns. I hear the PAP shows with the amp, and a rep from PAP says they are the best of the best with my speakers. I get musical, but what about some meat on the bones. I currently use a 50 or so watt KT88 pentode amp. Is there really no comparison. I have Transition Audio Altec 1570 B with 811A tubes. Thats 140 or so watts. Much thicker sound than the KT88 pentode. Altec is not as clean and clear. Not as accurate to there real instrument.
I want great recreation of real instrument sound. Fast. I don't want mud, but I do want depth and richness. Not lean and clean. Warm and clean and accurate. Truthful to the source.
I’ve had a LM508IA for the Pap horns for the last year and now just taken delivery of a LM805ia to now drive the Harbeth 40.2s. These amps are impossibly good if given a good pre. Possibly my favourite amp ever... do love them. They are awesome. Enjoy.
I'm not going back to my speaker. I will stick with finding the right amp for the speaker. I like the sound from my speaker. It's good enough.
My room is 18x20x9 and has open boundries to the rest of the house. I probably listen in the mid 80 db range. I don't play loud. Would rather the magic happen at lower volumes. In the 70dbs.
At 54, I still have exceptional hearing. When I got my kt88 amp I was shocked at how much more accurate and real the tone was. It gave me a better understanding of what could be obtained. How close to live sound could be.
I want to keep my $ at say $6k. Happy to get used. Warranty don't usually mean much. Ampsandsound wanted me to spend $600 to ship my amps back (for a second time in 1.5 years) because the bios cap had failed. I had a local guy swap the cap. Justin the owner said he would never service my amp again. I guess he did not like my feedback. His amp hums pretty loud. When the local power gets bad at night it roars. Hard to relax in front of tv when in idle as the hum is so loud. So, any new amp needs a good regulated power supply that can deal with dc and spurious voltage that gets between the neutral and ground. Otherwise I'm jumping out of a pot.
I mention Whammerdyne as Pat says his amp is built as such and dead quiet. Its power supply can handle the utility noise. Of course any noise via my preamp or sources will only be amplified. I get that.
You seem a good candidate for Whammerdyne. I've heard one amp once and was impressed. Design approach and engineering are first rate. The amps are built with substantial power supplies with close to 3db of clean dynamic headroom and they are very quiet. They have one amp under $6000. Because of your room size and it being unbounded, finding a way to stretch for the $8500 DAM2 monos (or finding a pair used -- difficult -- for less) would I think remove any risk of sensing insufficient power, given your listening habits and preferences. Given your power problems, an isolation transformer might be in your future.I'm not going back to my speaker. I will stick with finding the right amp for the speaker. I like the sound from my speaker. It's good enough.
