. . . Compared to my 1000W modded JC-1 monoblocks driving the same speakers, the SET monoblocks beat the SS in every category, highs, bass and slam.
I was open to believing every word, until I got to your last word, "slam."
I don't see how your 35 watt SETs can deliver more "slam" than JC1s.
The problem in an SET if it really is that heavy, might be because its built in an attempt to make power. Getting over about 7-8 watts is tricky, as its so hard to make bandwidth when you get over that power level. Usually they wind up being bass shy.Big iron = bassballs
if a amp doesn’t hurt when you try to pick it up it’s not an amp... it’s uhhhmmm interior design![]()
Depends on how its executed! This is a common saw, and its not entirely accurate.So, the phase splitter is evil...
The real problem is that most push-pull amps are single-ended combined with push-pull outputs. This results in a bit of 5th harmonic that gives them a certain sound. The only way to avoid this I've found is either go single-ended all the way (and get a 2nd harmonic, based on a quadratic non-linearity) or go fully differential from input to output and get a 3rd harmonic (cubic non-linearity). The ear treats both the 2nd and 3rd the same way- they both contribute to 'warmth', 'body' and the like.
Differential amplifiers make excellent 'phase splitters'.
The difference is that an amp based on a 3rd harmonic will have about 1/10th the distortion at full power and will have overall less higher ordered harmonic distortion, resulting in a smoother and more neutral sound. If not running feedback, it will also have a cleaner 1st watt than an SET, and share with it a linearly decreasing distortion signature as power is decreased to zero. Most push-pull amps have distortion increasing below a certain power level (4-6% or so of full power). It does not seem to matter if that fully differential amplifier is transformer coupled and even if it has interstage transformers, the 3rd harmonic will still be the primary distortion component. I prefer to go transformerless of course![]()
It was my understanding that 2nd order creates a more "open" sound whereas 3rd harmonic is a "hooded" sound. Trumpet, for example, has a lot of 2nd harmonic but Clarinet has more 3rd harmonic, which gives it that "hooded" or more "closed in" sound. One of the best PP tube amps I ever heard was from Vacuumstate, which was fully differential from input to output (It was not OTL though...had nice Lundahl output iron). I don't know if I liked it more than a good SET but it was definitely making good music.
I think you should build a good single ended OTL. Aries Cerat makes one (it is huge and hugely expensive for 20 watts) that I haven't heard yet but hope to one day in the not too distant future. Transcendent Sound makes a budget kit one, which does use feedback (The Aries does not) but I heard one once on some Klipsch Cornwalls and it was really something to hear.
'Slam' has nothing to do with amplifier power, and everything to do with how the amplifier interfaces to the loudspeaker! Since SETs do not employ feedback, they have a higher output impedance and so tend to act as a power source rather than a voltage source. So the kind of speaker that a solid state amp works on will cause an SET to fall flat on its face, but the kind of speaker designed to work with an SET will likely sound horrendous with an amp that acts as a voltage source.
For more on this see:
http://www.atma-sphere.com/Resources/Paradigms_in_Amplifier_Design.php
A lot of people including degreed engineers often argue the points I make in this paper. I didn't make this stuff up- it is simply because they are for whatever reason (youth?) not grounded in audio history. The Power Paradigm is what was around before the Voltage Paradigm rules were promoted by Mac and EV in the late 1950s, but took over 20 years to take root. Now everyone thinks speakers are 'voltage driven' but obviously that simply isn't the case.
(...) A lot of people including degreed engineers often argue the points I make in this paper. I didn't make this stuff up- it is simply because they are for whatever reason (youth?) not grounded in audio history. The Power Paradigm is what was around before the Voltage Paradigm rules were promoted by Mac and EV in the late 1950s, but took over 20 years to take root. Now everyone thinks speakers are 'voltage driven' but obviously that simply isn't the case.
"So the kind of speaker that a solid state amp works on will cause an SET to fall flat on its face, but the kind of speaker designed to work with an SET will likely sound horrendous with an amp that acts as a voltage source."
Yes. In drivers like Altec, high impedance low damping low watt SETs do much better bass and slam while high watt low impedance high damping SS can choke them.
Using SETs on apogees and acoustats is a joke.
There is an enormous!! difference between harmonics that are part of instrument timbres and those caused by distortion- in the above post you are conflating the two and it simply doesn't work that way. The ear treats both the 2nd and 3rd harmonic (when it distortion) exactly the same way. The 3rd harmonic is present in SETs at a higher level than it is in a fully differential amplifier; if what you said were true then SETs would be unlistenable as they would sound too 'hooded' and 'closed in'.
The thing about amplifiers is you need bandwidth. If you want the bass to be really right, then you need bandwidth to 1/10th the cutoff frequency- so if 20Hz is desired then you need to go to 2 Hz. Same on the other end- if you want to go to 20KHz you need to go much higher - at least 100KHz. You can see right away that no SET is going to do this. Now you might ask, since many people do, 'why have all that bandwidth if you can't hear it?' and the answer is phase shift. While you can't hear the phase of a sine wave, you can certainly hear phase shift over a frequency spectrum in the form of tonality and soundstage. Get the phase shift right and the amp has a more natural more musical high end, and a deeper wider soundstage. This will also give it the ability to sound faster and more detailed, but in a relaxed way without brightness, since these are also perceptions of low phase shift.
When the filter (which is what an output transformer is) imposes a 6dB/octave rolloff, the phase shift components can be seen to 10x or 1/10th the frequency of the cutoff (IOW the -3dB point) depending on which end of the spectrum the rolloff is located. So a 20KHz -3dB point has audible components down to 2KHz. This has been known a long time; its why the early H/K Citation series had such wide bandwidth. It sounds more real.
We recently repaired a single-ended OTL here in our shop (belonged to a local customer who replaced it with a set of M-60s and then went to MA-1s) and got to compare it to our amps on a benign 16 ohm load. It was a nice sounding amp; the fact that the customer immediately replaced it should tell you what you need to know. This would be entirely anecdotal were it not for that customer placing threads on audiogon about his experiences.
Speaker drivers were often overly damped mechanically and depended on the high output impedance of the amp to get proper bass response, so when a low output impedance amp was used there'd far less bass than necessary and it does indeed sound "choked". Modern drivers, even ones intended for SET amp use have gone the opposite direction and have spiders and surrounds that are as flexible as possible, for example AER's ultra-thin foam surrounds, these are more efficient AND work well with most all amplifiers, or at least there isn't that massive difference in performance between SET and SS.
Yes those speakers were highly damped to go with the amps of those times. Something like an eminence woofer will be the opposite
Your opinion is just that and not a fact (fact is that it works well) but you should stay away from any thread that is even hinting at a technical discussion.
