Shunyata vs other types of grounding devices
It would help IMO. You could always chat with Shunyata. The founder of that company is extremely sharp. I used an isolated, ionic grounding rod from Lyncole (similar to Erico) in my dedicated room to good effect. I am also interested in fiddling with Tripoint. Lowering the "noise floor" does impact the music.
Caelin is also a member here and contributes regularly
........................ I used an isolated, ionic grounding rod from Lyncole (similar to Erico) in my dedicated room to good effect....................
That high tech ground rod should be connected at/near the service entrance of your home! Never to any circuit in your room.
Jfrech, I have admired your system on Audiogon. You owe it to yourself to experiment in the grounding arena. See if you can try the Entreq or Tripoint and tell us what you HEAR.
Well then, maybe I mis-understood what you did. Could you describe your setup again please using different words?
Speedy, what have you done to optimize "grounding" in your personal system? We are all addicted to Best it seems. What does that constitute for you in terms of equipment?
