soulution 760dac i2s
Yannan
2
34
hello everyone
I am a user of Soulution 760dac. I recently discovered that the i2s interface in the output interface of 760 has the best sound. But I can't find the definition of this interface. I sent an email to the official but they didn't reply to me. I contacted them on Facebook but they didn't reply to me either. The local agent is not aware of the use of this interface, so I would like to ask for help from everyone. Does anyone know what the line sequence of this interface is? I have used the i2s output of Eversolo a8, but some of it can be played but some will be stuck. Its line sequence is like this. If there are users who know this definition, please send it to me. Or if you have other contact information of the original manufacturer, please send it to me.
Thanks
A quick search found this timing diagram of the i2S data stream. I "THINK" this is what you're looking for? If not my apologies.
Use at your own risk as I make no claims about the source. :)
Thank
Thanks
This definition may not work, because soulution uses the HDMI interface and I found that this interface has at least 8 sequences. If there is no correct sequence for this machine, I may not be able to use the i2s interface.
Are you asking for the pin out of the I2S connections? If so, the pic shows the two options for the HiFi Rose RS130 streamer. The Rose software allows the user to select which option, A Mode or B Mode. I looked at the similar pinout of my Mola Mola DAC and it shows the pin outs for A Mode so that’s what I use and it works.
I tried to look in the Soulution users manual but on their website the manual is a blank page so no help :(
