Streamer DAC for Tidal
Rexp
845
316
73
60
So far I have auditioned:
Naim NSC222
Hifi Rose 150B
Cambridge Audio Edge NQ
Electrocompaniet ECM1 mk2
Nothing great so far, any recommendations?
Cheers!
Rex
Tried the Cambridge Audio EVO 150, its class D power amp stage is pretty bad but used as a pre into Cambridge Edge W power amp it sounded pretty good!
Unfortunately no Auralic dealers near me, will check out Lumin, although I have found them overly smooth in the past.
Recently announced, but not yet available (nor yet reviewed), but perhaps worth investigating if you keep an open mind regarding branding, the NAD M66 ticks all my required boxes on paper - and a lot more if I was into vinyl.
I'm wanting to upgrade my digital front end and have a short list of contenders, including some you list, but I certainly won't make a decision until I've seen and heard the M66.
Reactions: wrxsti and Rexp
Listened to the Eversolo DMP A6 Master Edition and TEAC UD701N today.
The TEAC is a definite contender, although their app is quite poor and as usual Tidal Connect sounds bad. Roon is an option that I wasn't able to test.
You might want to check out a Gold Note DS-10. I’ve heard it a couple of times and thought it had bang for the buc.
Reactions: Rexp
Heard an Aavik S280 today, didn't sound great, although it was via an Aavik C280/P280 pre/pwr which is Class D...
Other thing to note, I did prefer the Aavik app to Roon, which seemed to screw with the imaging.
I wanted to try Aavik after seeing the video below which I thought was using their Streamer DAC but on closer inspection looks like a Linn Streamer DAC is the source, fyi @Mike Lavigne
Heard the following yesterday:
Cocktail Audio X50D streamer into Luxman D-03x CD player/DAC via USB. Sound lacked emotion with Nina Simone's 'Stars (live)'.
Auralic Aries G2.2 streamer into Vega 2.2 DAC. Sounded a tad processed.
Cyrus Classic Stream. Sounded good! Even made normally harsh albums like ' Walter Smith III - Live in Paris' sound listenable.
Need to go back and listen again in a more highly resolving system than the entry level Cyrus amp and Fyne speakers they paired it with.
