SUT for Ortofon SPU Meister
jeannyp
10
5
68
66
I am seeking for your recommendation of a step-up transformer for the Ortofon SPU Meister (specs below). Also, if there's anyone who has experience with the Silvercore Reference SUT specifically designed for Ortofon SPU, I'd appreciate it if you can share your impressions.
Output voltage at 1000 Hz, 5cm/sec. - > 0,32 mV
Channel balance at 1 kHz - 1 dB
Channel separation at 1 kHz - 20 dB
Frequency response - 20-20.000 Hz
Tracking ability at 315Hz at 4 gram - 70 µm
Compliance, dynamic, lateral - 8 µm/mN
Stylus type - Nude Elliptical
Stylus tip radius - R/r 18/8 µm
Tracking force range - 3,0-5,0 g (30-50 mN)
Tracking force, recommended - 4,0 g (40 mN)
Tracking angle - 20°
Internal resistance - 1,5 Ohm
Recommended load impedance - > 10 Ohm
Cartridge body material - Wood
Cartridge colour body/shielld - Black
Cartridge weight - 30 g
