Techdas titanium screw
Yamamoto and TechDAS do use a different Titanium Alloy.
I am sure, both are finding arguments for using their company receipt .
The Torque depends on Cart and headshell. My Etsuro Gold does not like high torque, my AS Fideles likes high torque, same with headshells, Wood or carbon headshells mostly do not like high torque, most metal headshells need high torque.
Mostly I prefer different torque for the 2 screws, sometimes I even use different washers.
Dear Shakti,
Thank you very much for your quick response i will be experimenting and will post my findings also once done.
Dear Shakti and other users can you tell me what the differences are between Techdas Titanium screws and Yamamoto Titanium screws more specific?
And which range are you seting the torque in (C)Nm?
Dear Amadeus,
I tried Techdas titanium screws in a couple of setups over standard ones. every time the sound became more fluid and tactile. strongly recommended if you don't have a very soft or lean sounding setup. I use 0.07Nm torque and no washers.
Reactions: amadeus
Dear Amadeus,
