Have you got one of these, Stephan?with 1:10 SUT a good phonopreamp too![]()
Tube Repro - Bottlehead
The Tube Repro is designed as a versatile tape head preamp that works well with medium to high inductance playback heads. It has been developed from the start as the perfect match to Flux Magnetics Extended Response playback heads. It can output both single ended signals at the consumer level...bottlehead.com
Here is mine, calibrated and measured by myself.I can't quite read the scale on yours. I usually set the upper frequencies at about +.5dB.
I can be as anal as anyone else, however, flat FR has almost nothing to do with sound quality.
Flat FR is a pre requisite thats all .Here is mine, calibrated and measured by myself.I can't quite read the scale on yours. I usually set the upper frequencies at about +.5dB.
I m not refererring to your test .That is true of ANY statement, made by ANYONE at ANY time, in a conversation, article or a review.
I don't think, however, that it is true ENTIRELY, as there are such usually some common traits.
If you are referring to my particular test, then its purpose was narrowly defined: to figure out which of many decks in MY possession should "I" use for making MY recordings. That question was satisfactory answered.
I don't see it that way, and the plots, posted here, could be considered either flat enough, or not flat, as there is simply no established , as you put it, prerequisite, in existence. There are some very fine sounding machines with FR variation on the order of +/-1dB, and also poorly sounding one that measure much better. So I just don't put too much credence in FR measurements.Flat FR is a pre requisite thats all .
Its a basic requirement for good sound ,
I am asking YOU: what is the require prerequisite flatness to FR that separates acceptable from unacceptable?Just ask any well known recording engineer
Look thats fine +- 1 db but you have to mention the range as well for example over a 40 hz - 16 khz range , be more specific .There are some very fine sounding machines with FR variation on the order of +/-1dB
For me all that counts is that my machines with good tapes can smoke some high $$$$ stacked digital components at a show / dealer .
Meanwhile my studer is connected to a wall outlet using a simple power cord and those at the dealer are connected with arm thick cables costing thousands of $$$
If i achieve that my goal has been achieved and i am happy![]()
yes but andromeda has that covered alsoLike I said, when I calibrate a machine I strive for flatness, and Telefunken M15A was one of the easiest and best behaved machined in calibration.
It turned out, it still produced, what was agreed upon between several listeners, dark sound. And if you read audiophile publications, dark sound is associated with rolled off top. Go figure...
I like my levinson digital and it can do some things tape cant .It is all in the format. A great tape is unsurpassed by any medium imho.
