Tell Us What Tweaks You Use That You Swear By
kach22i
Apr 21, 2010
1,593
210
1,635
Ann Arbor, Michigan
www.kachadoorian.com
Cardas Frequency Sweep and Burn-in Record
http://www.cardas.com/content.php?area=products&content_id=7&pagestring=Accessories&product_id=5
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
PS Audio power regeneration. Mine is an older unit:
But they have moved on to newer models.
It is fun to change the frequency and see if there is an impact. Many other tweaks don't lend themselves to simple A/B (you can't change cables fast enough for example). But this one is easy. Set it to 60 Hz and then dial up and down and see what happens (give it a second or two as the effect in your electronics is not immediate due to capacitors holding charge). You can even have someone else do it so that it is a blind test!
Be warned though, the boxes generate a ton of heat and are big and heavy. Mine is heavier than a higher power amp yet it only has enough juice to power my front-end.
In my testing with DACs, there is an upside down U-shape graph impacting performance. You change the frequency up and the sound gets better but then when you go a notch or two, it degrades again. This makes it easy to find the optimal point. And gets past placebo effect that "more is better." :)
Rutgar
2
Dallas Area
mysite.verizon.net
Interesting. I have about 250 hours now on my MM2's. I have just been using a CD that has a veriety of bass, highs, dynamics, etc. But I wouldn't mind trying somethng that might speed the break-in process up a little!
soundofvoid
Apr 22, 2010
173
11
1,405
Athens/Greece
When i am not satisfied with the sound i change the music program.If this doesn't help,a shot of Southern Comfort on the rocks makes things sound nicer!
Of course this works best with classical and operas...
For listening to rock and pop...usually beer does the trick better!
John....Southern Comfort?? I would have thought you would have said Ouzo ;)
jadis
12,465
5,575
2,810
Manila, Philippines
VPI Bricks. I bought one in the mid 80s. I liked them enough to buy 2 more here from a friend. I don't if it's just me, but I do hear some improvements by placing them on top on my amp's transformers.
MylesBAstor
81
1,725
New York City
Yes the SC especially works wonders when you have a headache from listening to the tweak ;)
I've been wanting to say something about tweaks for a bit but today's instance is just another example of what I was going to point out.
I think the less tweaks, the better. Too many tweaks is asking for trouble eg. the better one's system, the less tuning it should need. Or-there are inherent compromises in lower priced equipment, say the construction of the power supply, that is compensated for by the AC cord or PLC. In many cases, I think one is just trading one coloration for another that happens to match that component. But jumping onto that tweaks bandwagon without having some sort of trial is asking for trouble.
The latest incident goes for AC cords. Now I know some out there use PLC, etc on their equipment but I've yet to hear one that didn't color the sound to some extent, choke the sound, compress the soundstage, roll off the upper octaves, etc. for a variety of reasons! The same goes for AC cords-and the experience with my new amp just goes to illustrate my point. I had been using PC #1 and it worked well with my previous amp. When I installed my new amps, I just kept the same cord and connected it to the electronics. I was listening quite a bit last night and the sound was just rolled off, compressed and sluggish. Yes, it got better after a couple of hours but I wasn't happy. So today did some more listening and I was still hearing the same colorations; so I unhooked my previous fave PC and inserted the cj stock PC. Low and behold, the dynamics, extension, solidity, etc came back. So whether the PC was choking off the bigger amp, etc., the lesson to be learned is never to assume anything.
And I think the same goes for most vibration isolation products. The question is at what frequencies does the product absorb, which do they transmit and which do they reradiate? This in the end will be component specific and unless one can design a product specifically for that piece of equipment, one is asking for trouble.
JackD201
1,429
1,820
Manila, Philippines
@Steve
Steve you're a doctor so maybe I should ask you. Listening is always best after a mild or medium work out or light physical activity like taking a 30 minute walk or an easy going round of golf. Aside from my having more energy, my hearing is usually more keen and I find myself listening with the preamp a couple of notches lower with equal satisfaction. Any physiological explanation for this? Thanks!
Jack
MylesBAstor
81
1,725
New York City
@Steve
Jack
Yes exercise releases at least two powerful central nervous system stimulants among them norepinehrine and epinephrine. It's been show that 30 mins of exercise/day (along with traditional Rx) --which releases norepinehrine and epinephrine--also has a big impact on people suffering from depression (I think in part exercise impacts the ruminations that people suffering from depression go through).
kach22i
Apr 21, 2010
1,593
210
1,635
Ann Arbor, Michigan
The "trouble" is in finding what vibration isolation product works for that specific component. This sort of "trouble" is fun for some of those afflicted from audio nervosa, it just a challenge not a problem.
es347
35
1,620
Midwest fly over state..
This isn't a tweak per se but does wonders for me. About 30 minutes prior to a listening session I pop in those marshmallow-like ear plugs. It really lowers the apparent noise floor inside my head and when taken out, the difference before and after is stunning. It allows discernment of all the subtle nuances. It's not permanent obviously but it sure makes a difference. On a further note, I always use the ear plugs when mowing, trimming, running my air compressor....or when I'm around any loud noises...grandkids, etc.;) With all I have invested in this hobby that is so dependent on my sense of hearing you can bet I'll do whatever to protect my ears and therefore my audio investment.
MylesBAstor
81
1,725
New York City
I agree with you to some extent. I think what I was thinking when I posted was the cost of these "tweaks." It was different when the Mod Squad tiptoes were $5 each :)
Gregadd
1,796
1,850
Metro DC
My favorite tweaks
Have your ears cleaned.
Actually I suggest avoiding alcohol products during serious listening sessions.
Get a massage. Remove all restrictive or tight clothing. Not nude. from Harvey Rosenberg
Listen alone. Don't have to worry if your companion will be impressed or disapprove of the money you spent.
A fine cigar or pipe tobacco. From Harvey Rosenberg Appearently the smell of fine tobacco products is relaxing. Those who fear cancer and other lung diseases may try other aroma therapy.
For vintage equipment -a 20lb cast iron barbell or plate. Place it overt the old style transformers. Caution make sure the cover is strong enough to support the weight. Not only does this act like the VPI magic brick, it keeps the cover form humming along with the music. Also it helps couple the component to the anti-vibration device like tip toes. I place one on the transformer of my ML CLSI also use them on mini-monitors to help couple them to the stand.
Finally cleanse the palette. I try to use some chamber music or female vocals at the start of the listening session.:D:cool:
For you married guys- Take out the trash and perform other duties that can cause friction with spouse.:D
