After receiving the PCM156 this week, I can say definitively it works well with Grimm MU2 which honestly I did not expect. Really good. Immediately cleans up a layer of grunge you didn’t know was there. Makes performers more present. Allows you to hear musicians individual parts more clearly. The imaging gets more distinct and solid. Bass gets more textured tight and resolved. 3D localization is more than i’ve ever had in any system. Now you can track precisely imaging in space with the electronic music I like to listen to and hear vertical and depth detail. Stuff like Chocolate Chip Trip from Tool was revelatory - they put a lot more in there than I ever knew! Contemplating the upgrade to statement PC and ground city but things are so good right now I honestly don't see the point. Curious how it will do with the M10X and my Synergisic Research switch now For reference, I've owned Denali V2 and Everest conditioners as well.
If one uses a isolation transformer such as an Equi-Tech or a Torus, and then one plugs a Puritan into the Equi-Tech or the Torus, what noise is left for the Puritan to operate upon?
I've replaced the generic wall outlet which the Puritan 156 connected to with a FURUTECH FT-SWS NCF,
and if I'm not imaging things there's a noticeable improvement!
I'm still with the basic power cable and thinking to upgrade to the puritan ultimate,
but I'm seeing people got great results with high-end stealth audio, Shunyata cables.
Could it be just an overkill and the ultimate cable should suffice?
One possible explanation. In some environments, It can be difficult to hear the inherent background noise until you insert another noise reduction device resulting in further noise floor drop. Can be very challenging to quantify until it is gone.
A recent review (URL below) of the passive Puritan 156, including objective measurements.
Apparently, there's measurable leakage between the purportedly "isolated" outlets, plus it doesn't handle stray DC well.
