Thread: A Search for Truth and Tonality, Part 2 ...
Yes, I saw and knew tons of stuff before that apple got bitten by the totally nude and gorgeous goddess of Eden.
Then after that things started spiralling in all directions from the apple tree!
...And look at us now today. :b
From http://www.whatsbestforum.com/showt...s)-Preferences&p=109250&viewfull=1#post109250 ...
Listener fatigue or you heard everything that was wrong with a couple of hundred records. I find the opposite. Given enough time to listen to something, I'll acclimate to it and stop hearing its flaws
Interesting approach by Tim. For me, it's the other direction, assuming I'm listening to an "ambitious" setup rather than just any old sound system. If the sound quality has stabilised then there will be a distinctive distortion overtone to what's played, the "everything sounds the same" syndrome to some degree: if a pleasant one then you just go with that tone, not a problem. But frequently there is a more unpleasant, irritating edge which, once I'm aware of it starts to grate for me, so I either look for alcoholic relief or begin glancing at my watch more and more often ...
Frank
From http://www.whatsbestforum.com/showt...o-transparency&p=109792&viewfull=1#post109792 ...
I didn't say that 100 dB is needed. I'm quite sure that 90 dB is plenty. And as I'm sure I said many times, even 80 dB is probably adequate to guarantee transparency related to distortion and noise artifacts.
Agree 100%. 80dB is plenty, in fact real 60dB dynamics does an excellent job, I have no argument about "miserable" spec's here, providing everything else is working correctly. Figures of 120dB are pure navel gazing, as far as subjective sound quality is concerned ...
Speaking of distortion, worrying about 0.01 percent (-80 dB) in the face of 0.5 to 10 percent from your speakers is misguided IMO.
Disagree!! I'm sick of seeing this nonsense over and over again: in the part of the spectrum that counts, which is everywhere where big, beefy bass doesn't hang out, it is possible to get a consistent distortion figures in the region of 0.1%, at realistic, meaning relatively high sound levels from good quality units. Speakers are not the problem!!
Frank
From http://www.whatsbestforum.com/showt...o-transparency&p=109935&viewfull=1#post109935 ...
I think that is part of the issue. We still rely on ancient measurements and have not woken up to the complexity of data/signal dependent non-linear distortions. Dr. Geddes has a very nice article on fallacy of THD measurements and how it assigns equal weights to harmonics and how this is not right perceptually due to how well the signal masks its harmonics. As we move to higher harmonics, even though their levels drops rapidly, they may actually become more audible.
Nice to see mentioned. With a reasonably transparent system it is ridiculously easy to hear how different amplifiers distort, no matter how the brilliant the supplied conventional spec's may be. So, as long as people in general persist in the "fantasy" that everything has been sorted out in this area of electronics, from the point of view of the designers, then the industry will continue staggering around in the swamp of incomplete understanding ...
Frank
From http://www.whatsbestforum.com/showt...o-transparency&p=109948&viewfull=1#post109948 ...
I tried two lm4562 op amps in series, compared with a piece of wire. Output was about 3Vrms. I could not tell when the two amps were in the circuit or the wire, they are audibly transparent to me. And IMD is at 0.00005% at under 4Vrms output. THD is just a tad higher, i think 0.00003%.
At some point, we have to cave in and admit that something is audibly transparent. OK, I have to, the rest of you don't ..
Trouble is, an audio system is more than 2 very high performance audio opamps in series. We're back to a chain made out brilliantly tempered, highest quality steel links, except that at certain points we sustitute a link or two made with elastic bands, or a bit of fencing wire found under the house, and so on. Obviously, the integrity of our chain is bound up in those superbly made links, we can safely ignore the ones we're not so sure of, or don't know enough about ... or so some "gurus" in the audio game would perhaps claim ...
Frank
From http://www.whatsbestforum.com/showt...o-transparency&p=109958&viewfull=1#post109958 ...
I have had the opposite experience with LM4562 - I bought a pair of active speakers which used them in the crossovers. But I found the sound harsh at the top end. Rolling out the LM4562 in favour of a (generally considered inferior) NE5532 improved the sound - the harshness was reduced but not eliminated. I have a hypothesis for what's happening but I dont have any measurement data.
Which nicely reinforces my previous post: an audio system is always, always, always a combination of elements which will yield a certain result, depending upon myriads of factors. Simply substituting one component for another will highly likely alter the perceived sound, and that change of quality is only very, very vaguely dependent upon the "intrinsic quality" of the component. Frequently, inserting a better quality component will make a system sound worse, because it is more clearly revealing that other parts of the setup still have problems: sounding harsh in the top end is the classic signature of system actually becoming more transparent, and revealing my favourite baby: low level, high frequency distortion ...
Frank
From http://www.whatsbestforum.com/showt...o-transparency&p=110061&viewfull=1#post110061 ...
I've tried listening to audio with music I really dislike. That helps me stay focused on the sound. Give me good music, even decent music, and I'm going to listen for the sound of the music, not the "pre-echo"
Tim's got the right idea here: you listen to sound which nominally is unpleasant to yourself, and this makes it very easy to pick problem areas. This is why I use "bad" recordings; every weakness is subjectively intensely emphasised and you don't have to play with any DBX nonsense to know that there is something wrong.
The big advantage of that is, that when you have the "duds" sorted out, by improving the system, is that everything else you listen to is then lifted by a decent amount.
Frank
Yes, true Frank, but the time wasted listening to bad music is gone forever.
...Cannot be recouped, ever!
And that time lost could have been used for more pleasing life stance,
like listening to good music for instance. :b
Bob, remember I'm not talking about bad music, but "bad" recordings! The latter can contain some great treasures, as for example live Art Tatum, and many other famous artists performing in front of a crowd. And truth be known, when a system is really firing then you can listen to music styles that normally leave you cold, because you can appreciate the tonal colours, and the energy of the performers.
Of course, I do draw a line somewhere -- rap will forever never pass muster, under any circumstances ... !! ;):b
Frank
From http://www.whatsbestforum.com/showt...o-transparency&p=110107&viewfull=1#post110107 ...
Musical peaks aren't usually even "a second or two", but rather a fraction of a second. Even well-recorded rock and jazz will hit peaks of 120 dB when the average level is closer to 100 dB, and with classical the average volume ( when peaks hit 120 dB) is more like 90-95 dB. Loud, sure; unreasonably loud, no way.
Which is why a sorted out audio system should be able to reproduce music in a convincing fashion. Studio monitors can do from well above 110dB to over 120dB peak without much trouble, so they should be able to get it right. But in raw form they fall well, well short, for the reasons mentioned in my other thread.
Frank
In reference to post #75
Tricky, because everyone of us is so different in his own level of 'music stamina acceptance' .
I guess it has to do with our uniquely own level (blend) of testosterone and blood tissue cholesterol samples. ;)
I don't know about others, but my "stamina" is totally dependent on how clean the sound is. So, I can listen to my HT at high sound levels all day long without problems, on all sorts of material, but the studio monitor combination is steadily bugging me more and more, because I am able to register its distortion characteristics without any trouble at all now. Which means, running it at effectively very low levels, otherwise it's just too unpleasant to tolerate for any length of time.
Frank
From http://www.whatsbestforum.com/showt...o-transparency&p=110118&viewfull=1#post110118 ...
Are you guys listening at 100dB averages? And you think you can hear audiophile subtleties? Hell it's a wonder you can hear anything.
Yes, that's why musicians all wear heavy duty hearing aids after 6 months of working at it, their ears are totally shot by this stage ;). The answer is, that the hearing system is extremely tolerant of clean, undistorted high level sound, this has been noted many times: once you add a heavy dose of distortion the ears go into severe overload very quickly, and the damage gets done ...
Frank
---"Tolerance"; that was the word I was in search of. :b
...Not only regarding quality (positive or negative attributes) of the music recordings themselves,
but also of the emotional impact from the artist(s) performing their arts.
- Classical music rocks my boat, but not everyone is so enthused.
My theory on this is that many people "adjust" the sound of their systems to suit, for their ears, popular music -- jazz, blues, etc. And in my experience listening to other people's setups this frequently leaves the sound very threadbare, uninteresting, particularly when from digital sources. Good classical sound sets up a very rich texture of tones in the air, the harmonics weave in and out of each other; there is almost an other worldliness about the sound, your mind can swim through the collage of sound, and it soothes and enriches your soul.
But, if this soundscape is not satisfactorily created then it all can be a rather dull and wearisome experience, an intellectual exercise to follow what's going on, and not something to be "enjoyed".
Getting top notch quality in classical playback is not easy, so the lack of enthusiasm by some does make sense ...
Frank
