Townshend Isolation Podium
Marcus
560
555
1,155
crion
88
11
238
I had a previous air suspended model. It worked very well on several speakers I owned from full range 15" towers to smaller speakers. I'm considering the new model under my center speaker as it sits on a spectral brick furniture now.
It also looks like there are more options now to accomodate many sizes and equipment
It worked very impressive on wooden floor!
bonzo75
22,650
13,685
2,710
London
I used them under my Martin Logan summits. They sounded great but the downward firing woofer sent the sound through straight to the neighbours below, so I sold them off to another summit x owner and got myself auralex which sounded fine and blocked the sound.
The one designed for summits is similar but a hole in the middle. They also have parallel bars that do a similar function, and are easier to place the speaker on as all you need to do is lean back the speaker from one side, put the bar under, repeat on the other side. No need to lift the speaker up.
Purite Audio
banned
May 28, 2013
417
1
www.puriteaudio.co.uk
Foam won't make any difference to bass, it will just pass straight through, the platforms are designed to attenuate vibration from the loudspeaker into the floor, or vice versa.
Keith.
bonzo75
22,650
13,685
2,710
London
The neighbours stopped coming up
