Here is a picture of finished product. Kuro grounding cable. Bigger than I thought.
Can you carry it, how many kilos?
3 of those snake are mine. Looking like it wont be so small after all. I will let you know how it goes Tang, if you dont mind waiting patiently and not jump queue hehe. J/k.
No problem Hieukm, my fellow brave heart. I don’t know about the queue though.
Kind regards,
Tang
Audiophiles in Hong Kong have discovered an economical yet effective tweak to further improve the performance of Troy Signature and Troy Elite.
Above are the photos of the original power plug of Troy Signature.
They are cheap Oyaide C-029.
Several Troy user friends of mine replaced it with better plugs.
Some use Furutech NCF and others use Oyaide new Armored Series AP-004.
The swap is easy and no soldering is needed but the resulting sonic improvement is quite significant!
NCF gives higher reaolution whereas AP-004 is warmer and more musical.
The cost of this tweak is nothing when compared to the prices of Troy Signature and Elite.
Haha
Haha
Allow me to correct the comments regarding the plugs that are being used for the Tripoint Troy and Elite ground boxes: Miguel does not use the cheap P-029 plug but the P-079 guts with a 029 case (the latter only for cosmetic reasons).The P-029 does not have gold plated blades. Furthermore the Troy Elite plugs are specially treated.
Additional comment: Miguel just informed me that replacing the plug of the Troy Signature se and Troy Elite is not easy. So please be careful in this regard.
The gold blades jumped out at me also Rudolf. What I find bemusing though is that all the Oyaide range use exactly the same ground pin so the metallurgy of the L/N pins shouldn’t be relevant?!?
Hello Audiocrack,
Thanks for the info and asking Miguel.
Miguel may have chosen P-079 because of sonic character preference.
However, the Oyaide AP-004 is superior to other Oyaide series in many aspects. Most HK audiophiles prefer it to even the M1.
It's time for Miguel to re-consider.
BTW Let me guess : the special treatment given to the P-079 on Troy Elite is cryogenic treatment?
Oyaide never cryo-treat their products and one of the retailers of Oyaide in Hong Kong helps customers to send Oyaide products to overseas for cryogenic treatment at a reasonable charge.
Hi CKKeung,
Miguel is currently working on some new products and is in that regard thinking about the new Oyaide armored AC plugs.
As regards the special treatment: I am pretty sure (but to be 100% sure I need to check with Miguel) that it is not cryonegic treatment. I have seen him working at my place when he added dedicated grounding schemes and dedicated binding posts to a few of my audio components. He ‘polished’ these binding post with various materials to such degree that I had never seen before. Each binding post took him literally hours.
Where can I order this cleaning system ?
