How the heck is anyone in HK living in the shoeboxes they mainly inhabit, going to get those Divin monsters in?
Sawasdee CK,
I wont be attending the show. Maybe my agent would. I would be motivated to go if they have something that interest me but as of now nothing just yet. For me, AE attracted me with their grounding devices and also clean power devices. Their grounding things work very well in my system. However, their power cleaning devices didnt lift the performance of my systems.
I have the Dalby Celestial for half a month now. It makes me happy enough I dont want to try the Thor and buy two more. I heard AE will be presenting the new Troy Elite in the show. But at this point, I am done with grounding.
Best regards,
Tang
just found out that Miguel will be shipping me a new Tripoint Troy Elite next week.
thank you Miguel.
I'm excited to replace my Troy Signature on my sources with the Elite. then the Troy Sig will be moved to my dart mono blocks for chassis grounding. i'll be doing this in steps so I can appreciate what the step up to Elite does for my sources, and then what adding the Sig with my amps can do.
my wallet will need to recover before I can afford to add more Thor SE Master Ref grounding cables for my dart mono blocks, i'll start with the standard grounding cables there.
Congratulations!
The Elite was demoed at the small hifi show organized by Audioexotics in HK 2 months ago.
The sonic diff of with and without it was huge.
Please compare it against your Signature and tell us your views.
Thanks so much!
thank you Miguel.
thank you Miguel.
You are going to be amazed, Mike. This is going to be a very significant step forward.
thanks Rudolf. following your bold lead.
I have high expectations (I better for the $$$'s). but it's funny how sometimes until your ears actually hear a new step for the first time you are never prepared for the leap.
knowing what the Troy Signature and the -2- Thor SE Master Ref cables have done for my sources, at some point I was going to find a way to get some Tripoint love on my amplifiers, confident what that should/could do. and this approach raises the bar in both source and amplifier areas significantly. last night, per Herve's (Mr. darTZeel) instructions, I went to the hardware store and found some stainless screws nuts and washers to allow me to attach a ground cable to a specific stainless steel screw on the back of each dart mono block. I tested it and i'm good to go. just need the Elite to arrive.
Of the top of my head , these may not be entirely correct but in the ball park .
All in $
Troy :14k, not sure if still in production.
Troy SE : 21k
Elite :50k
Emperor : 60 k , no longer in production .
The Troy SE has 3 binding posts , the Elite 4 . LL21 has managed to hook up a large number per post , and get good results, forget the exact number . Obviously efficiency drops, the more one connects .
the Troy Signature is just under $22k with 4 standard grounding cables.
the Elite is just under $40k with 4 standard grounding cables.
the Thor SE Master Reference grounding cable is $5k for 1 meter and more for longer lengths.
Can someone please post the prices of the top Troy gear?
In all my time reading about Miguel's stuff in the last few yrs, I've never seen a definitive price list.
This is not a ploy to bash Troy.
I'd be a bit of a hypocrite if I did criticise prices since I'm spending on multiple Stacores, and their top platform is over €5k.
But I'd love an idea on how much a fully Troy'd system would be for multiple components.
How much is Troy, Troy SE, Troy Elite, Troy Emperor, and the range of grnd cbl options, from Standard, to SE, to Elite?
Additionally how many terminals are on each Troy box, and how many grnd cbls can each terminal support?
I have tt motor psu, tonearm, phono, phono psu, cdp, poss streamer and dac to come, pre, pre psu, monoblocks, sub amps, to ground, need to know how many boxes would be needed to cover comprehensive grounding of up to 13 components.
I ask publicly because I've emailed Miguel a couple of times, but he's not forthcoming w prices.
If there is sensitivity on prices in the public domain, please PM me.
