Triton v3, isolation, footers
Trentero
14
3
68
52
Hello,
I am a long-time reader, first-time poster. I recently purchased a Triton and I hope someone can offer some advice on isolation.
For example, are you using additional isolation? I have read that the Triton incorporates many anti-resonance properties so that additional platforms, etc are unnecessary. Are you using additional isolation anyway?
And if so, what are you using? The Triton comes with SSF-50 feet, which look pretty impressive. Has anyone switched them out with Stillpoints, for example? Any difference? Have you tried isolation platforms?
Right now my rack space is depleted, so the Triton is sitting on a large thick bamboo cutting board with three squat brass spikes that don't quite penetrate the carpet. I don't hear any need for improvement, but I'm curious to know how people have been experimenting.
Thanks much for your advice.
T
tima
5,056
5,723
1,235
the Upper Midwest
Prior to the v3 Triton, Hydras and Tritons work with hard and/or metal cones or Stillpoints type devices. The Triton v3 has footers designed for it - just place the unit on a solid surface. Remove your brass spikes. Shunyata prefer their own footers vs Stillpoints.
BlueFox
1,709
403
340
While the Triton v3 has better footers than before, I use Mapleshade Micropoint Brass footers under mine. I like only having three footers in contact with the rack, and they lift it up enough to make cleaning under it easy. Plus it sounds great.
https://www.mapleshadestore.com/brassfooters.php
Trentero
14
3
68
52
Thanks, guys. I probably should remove the brass cones. I read an earlier post where Caelin strongly warned against spikes.
crion
86
10
238
I'm using HRS footers and weights on top. These were much more important before in Triton V2 which was undamped basically. With the Triton V3 I could probably remove some of the HRS weights but they are there for now.
Bluedog
37
16
140
69
Boston
I had originally purchased the optional SSF-50 feet for my Triton V1 when they became available years ago. When I upgraded the Triton V1 to the V3, the unit was shipped back with new feet. I called Richard Rogers at Shunyata who told me to use the new feet on the V3, and use the older SSF-50 feet on another component, which I did, on a Innuos Zenith V2 streamer. Nice.
Bar81
129
19
98
A nice reasonable cost performance enhancing option to place beneath the Triton v3 is the Acoustic Revive RST-38H (available on ebay typically for about 50-60% of retail new)
