I think what this whole enchilada comes down to is: What kind of sound gets you off?
Years ago I worked for Audible Illusions so I had a Modulus preamp at home. I decided to do a straight wire bypass test on it. I had two of the jacks on the back of the Modulus wired together for the straight wire and I used my transistor phono stage directly into my amp (no volume control). There were simply two interconnects between the phono stage and the amp. Another set of jacks on the Modulus had two resistors on the input that padded the signal the same amount as the tube gain. I ran that resistor pad directly into the grid of the tube line stage (no switches, pots or anything). The output went through a Wondercap and then right to the output jacks. The transistor phono stage going directly through the two interconnects sounded good......but going through the single tube line stage sounded outrageously better. It plain sounded bigger, warmer, more real, more everything. No way anyone would have preferred the "straight wire". However, all this great sound was just the added coloration of the tube line stage.....plain and simple.
There was an article in the old FI magazine where they described a listening session: First they had someone stand in between the speakers and sing. Then they played a CD of him singing the same song through a system that had a solid stage amp (Aleph 3?). The CD sounded good and pretty close to him singing live. Then they inserted a single ended Class A tube amp for the solid state amp and everyone came in their shorts! Wow, you could now hear his tonsils....its so alive....its so pretty....its so big....it sooo.....everything. Then they realized that this sound was better than when he sang live! Yes, better than live!!!! (I might have some details wrong...its been a long time since I read that article.....but you get the idea).
It is not that all tube equipment makes the sound better (more liguid, sweeter, smoother, creamier, bigger, more space, etc.). Some tube stuff is quite transparent. However, tube gear is really easy to make sound good whereas transistor gear is unforgiving. If you do not pay attention to every little thing in a transistor amp then you will hear brightness, closed down sound, graininess, glassiness, peakiness, etc. You need to upgrade the fuse, damp the heatsinks (how many transistor amps have damped heatsinks?.....not many....if you run your fingernail down a heatsink and it goes zing...then you are adding zinginess to the sound of the amp. Transistors, regulators and diodes need to be damped if they are sitting up in the air on leads and not held to something. Binding posts are veiling and some are downright horrible. Some diodes sound really bad (fast, soft recover are nice). Then of course there is feedback......too much and you get a closed down sound relative to what you can get without feedback or with a small amount. If you have a really fast tweaky circuit like the Job then a small amount of feedback is OK. You have to get the square wave really steep and clean with no overshoot....then you get sweet extended highs. High open loop bandwidth is really cool.
If we all had access to amazing master tapes then it would not matter so much what we played them through (great solid state, tubes or hybrid). But we don't. There is almost always some harmonic richness and openness that is missing from our recordings. So it makes sense to have at least one tube piece in the chain to sweeten it up. Check out Srajen on 6 moons. He is always talking about the synergy you need to get the sound that "he likes". Usually it is a combo of passive or transisitor pre and a tube amp or a tube preamp with a solid state amp.
Do you really want to know how transparent your amp is? Very simple. Just do a straight wire bypass test on it. My friend Sieg Modes was doing this back in the 70s. You simply insert your amp in between a preamp and another amp and turn the preamp down the amount of gain of your amp. You need to mount rca jacks on the output of the amp. Remember, an amp is simply a gain stage. If it cannot drive the high impedance of an amp without coloration it certainly is not going to do any better driving a 2-8 ohm speaker. All arguments about transparency would end if someone were to do this. Transparency means.....no sound of its own. A great "sounding" amp is not necessarily transparent. How come no manufacturer in the history of audio has ever done this? Could it be that we don't really want to know? I mean....."I paid $50,000 for that color!?!"
I personally feel that if you tweak each technology to its max then both solid stage and tubes will get you dang close to "no sound". It used to be that transistor amps were considered a no no.....but in the last 10 years transistor amps have made great strides: Dartzeel, Soulution, Constellation, Technical Brain, Goldmund/Job, Ncore class D, etc. etc.
So, we are stuck with our "colors".....since all amps sound different then only one amp could be totally "transparent". I know, its the one you own....he he. We play at the highest level we can afford (or tweak to) and we pick the colors that match our other colors and if we are smart and keen we get some synergy and sound that is amazing. I think this is the best we can do right now. Enjoy you color!
