Some years ago I took an interest in a turntable from Versa Dynamics, now defunct, https://versalab.com/VERSADYNAMICS.html,
The owner and designer, John Bicht, gave an interview, attached, about turntable design that emphasized stiffness over internal damping- The main idea was that a turntable is a system that is only optimized when the vinyl is coupled to the cartridge stylus by a rigid system it will zero out external vibration.
Imagine we substitute your eyes and a computer screen for the vinyl and the stylus. If you’re on a boat going up and down on the sea, with your laptop in front of you, both you and the laptop are moving at the same time so your eyes don’t need to go up and down to focus on the laptop. If you sway in your chair your eyes will have to correct, but if your head were strapped to the seat, the seat bolted to the floor and your laptop glued to the table also bolted to the floor, it would prevent any difference in movement between your eyes and the laptop thus nullifying the effect of external motion. This is the argument for rigid coupling of the bearing to the tonearm, and against the idea of arm pods, air bearings and dissimilar materials between plinth and arm boards. Anything that decouples the bearing from the tonearm, or introduces materials that decelerate the propagation of external vibrations between the plinth, the bearing and the tonearm are to be avoided. The need for isolation of the whole system from external vibration is a different discussion. In a later post I’ll add on thoughts of turntable designs that adhere to these principles, but few designs follow this simple engineering logic.
