Tweeter/Mid min amp power rating for 20.1 in active setup?
Nuforce
287
144
130
49
Hi all,
I have a pair of mint 20.1s in light oak, and I'm currently running them active, using a DBX analogue balanced crossover.
I am currently using a class A plinius power amp for the tweeter/mid drivers and a pair of 600w Emotiva monoblocks for the bass drivers.
I'd like to replace the plinius with a pair of valve monoblocks, but I'm unsure what the minimum power rating should be? Ideally, I want to use 845 or 300B tubes, but it is tough finding anything above 40w.
Any thoughts?
Hi all,
Any thoughts?
What speakers are these?
How much you need depends very much upon how loudly you listen and how far away you are. Check out something like the online _Peak SPL Calculator for an idea about how much power you might need.
My gut says 40 W is likely too little. I personally would give up the 845/300B plan in favor of a more conventional 6550/KT120-class amplifier with 100+ W. The mid/tweeter panels cover a very broad frequency range. I don't know the 20.1's bass crossover off-hand, but long ago the 20's crossover was very low, something like 150 or 200 Hz, so they covered a large frequency band and thus needed a fair amount of power. Not like a typical conventional design with a woofer crossover that might be a few hundred Hz or even higher, and with a much steeper roll-off.
While I loved my old ARC amp, these days I would be talking with Ralph at Atma-Sphere ( @Atmasphere ). Modern OTL designs with excellent specs for the class and reasonable (to very high) power levels. But there are a lot of good power amps these days.
