Thanks Amir! That looks to be mostly bandwidth issues, same problem we have in our PCIe and SAS links. I'll have to read the article to see if he took the driver out of the picture.
Cool, we should try to hook up sometime!
Thank you for the link. The article (in my 2-second look) appears to define line-induced jitter as due to bandlimiting. I would certainly say that is by far the largest factor, but there are many others. However, I strongly suspect the other factors are in the mud for audio links. My guess for audio line-induced jitter causes would be (a) bandlimiting, (b) loss from long lines, (c) poor shielding leading to EMI issues, and (d) everything else at a much lower level.
On the coupling issue, I have a vague memory of an article discussing HDMI or USB links and discovering one of the benefits of a more expensive cable was the much better shield and heavier ground on the more expensive cables. However, for USB links, I still think galvanic isolation is the way to go.
(...) In fairness, whether a cable makes a difference or not is source dependent. So Paul's tests can't be representative of all situations.
Tim, the cable is $700 MSRP, the DAC1 Pre is $1,600. No doubt the cable is pricey nonetheless.
Again, in electronics there is no such thing as a digital signal; at least at the level we worry about it. Everything, but everything, is analogue: it's just that another piece of electronics chooses to interpret what is input to it as representing digital information. But what is actually happening at the circuit parts level, the voltages and currents, is all that mucky, difficult analogue stuff that can get you into trouble.
And if you don't take that reality seriously, then you can have degraded sound ...
Frank
Indeed and good point Amir.I wouldn't be surprised these guys are shooting blind in changing cables and not knowing without measurements, whether they have moved forward or back. Orb mentioned the same regarding Paul's tests: http://www.whatsbestforum.com/showt...yond-say-10-feet&p=53850&viewfull=1#post53850
Of course. And if someone really wants to talk themselves into an $800 cable (sorry about my earlier overstatement, I Googled and found a Diamond USB at much more...different length, no doubt), I wish them well. But it really is just data, noise and timing. All of them can be effectively addressed for much less than $800, though all of them cannot be effectively addressed by a USB cable, at any price. A good USB cable -- robustly built, overzealously sheilded, and meeting USB standards, is a good thing that's worth about 50 bucks. If you want to address noise (not just the noise in the cable) and jitter (not just the jitter created by the cable), put the $650 into isolation and re-clocking.
Tim
Tim
(...) Of course we can "what if?" And "what we don't yet know" all day long, if the mystery makes us feel better, but in the end it's still about $50 worth of cable and $750 worth of hustle.
Tim
Because you can make any improvements the premium usb cable has any possibility of make, and more, by addressing the issues at hand instead of buying an absurdly expensive usb cable. What if you make all those appropriate, systemic changes and the usb cable still sounds better? It won't, even though you may very well hear it that way.We can be sure that in a short time the expensive USB cable would be obsolete, as the DAC designers improve their models. But for the guy who is buying today and wants to listen tonight, if he has the money and this particular USB cable sounds better why not buying it?
As you so aptly stated in this forum “a product doesn’t need to justify its price tag, it need somebody willing to buy it”.
This will work regardless of the design of a DAC
And the simple answer of course is that people want "good" sound, not necessarily more accurate sound - see my posts on such in another thread - and the industry won't provide the information in an intelligent way so people can achieve such goals easily. There's a lot more money to be made, and it's much, much easier to do, in supplying "raw" components, rather than engineering overall systems to work properly. How many slick ads have you seen lately by companies aiming to do the latter ...??This type of argument is drifting away from the main point - why people buy the usd 800 cable and not the usd150 cable and the usd 650 more expensive DAC.
I expect the opposite
A couple of years ago you simply couldn’t buy an audiophile grade USB cable.
Likewise no audiophile cat5 cables
But as the popularity of file based audio increased overtime all what already has been proven very successful in the analog world, charging a premium for a wire, is now applied to the digital part.
With equal success.
I have seen $25 for 1 m Cat5.
$25 is way too low to be “high end”.
If people are willing to pay a couple of 1000 for a interlink, they sure are willing to pay the same price for a cat5 or USB.
So I expect the more popular file based audio will become, more “high end” digital cables will be sold at an increasing price level.
And that's what it's all about: stopping interference or unwanted interactions occurring: not whether a certain quality of copper was used!You may just find one that sounds better than the others - and no, I can't figure out why. It was a off-white cheaply constructed freebie, but it had a ferrite bead at one end.
