I agree w/ you Don. To me active Biamping should be done if you really want to get the benefit of using 2 stereo amp or 4 monoblocks in driving a pair of speakers. There should be an active electronic crossover network.
I think you are dead-wrong and aren't thinking this through clearly. First of all, we are not talking about using an AVR reciver. We are talking about using identical 220 watt stereo amps. Since you are using both channels of a stereo amplifier to drive one speaker, you are putting double the power into that speaker and now have isolated power amps for each speaker just like you would if you had a pair of monoblocks.
Since the speakers are set up for bi-wiring and they already have their own 14" subwoofer powered by an internal 1800 watt amp, you are essentially asking one channel of the stereo amp to drive the tweeters and the other channel of the stereo amp to drive the bass/mid woofers. Pretty simple load for each channel.
I think that by putting an electronic crossover in front of each amp would cause more problems than benefits in this case. I really don't want another crossover in front of the crossovers in the speakers causing wacky phase issues and adding the sound of the electronic crossover plus another pair of interconnects. The method I'm using is pure and simple and I only see positives and no negatives. I see a whole bunch of negatives if I decided to use an electronic crossover in front of these amps. There is no reason to make something more complicated than it needs to be and hope it will somehow sound better than the elegant solution being used.
