Steve williams
You should also get some better rack support for your front end sources. I am sure it is another big improvement.
I agreee
Many of us don't understand the science of the Typhon. Words seem to have a different meaning here (than in science & engineering).Tima
Many thanks. This is most useful. I can't pretend to understand the science but the Typhon has taken an exquisite system a few notches higher. Let the good times roll...
Pradeep
Reading the patent can be helpful to understanding the operation of the NICs in the HYDRA products.
I suppose calling it science, technology or voodoo is a matter of semantics. When viewed as a simple "black box" device, the TYPHON's fairly substantial performance can appear to be quite mysterious. It is not - try reading the patent, it is not that difficult to understand.
https://www.google.com/patents/US86...a=X&ei=TSEGVNzNHIXoggTn7IKYAw&ved=0CCkQ6AEwAg
I've owned Triton/Typhon for 2 years, very happy with them.
Question: Can a second power strip be plugged into Triton without losing out on SQ? I need a few extra outlets for secondary stuff like powered USB hub, turntable power, and a Rel T7 sub-bass speaker. Single 14awg power cord from strip to a Triton outlet. Have used Emotiva CMX-2 previously from Triton without any audible deterioration, but just wanted to be sure.
Thanks.
I tried the VD. Heard no difference in SQ. Sold it.
Will stick with Emotiva CMX-6 plugged to Triton.
Dear Caelin,
Is the below patent also referring to the Hybrid Zitron circuit in Sigma Digital to filter high frequency noise ?
https://www.google.com/patents/US71...a=X&ei=5G2PVMKPOcHlmAXfqoH4Cw&ved=0CDMQ6AEwAw
I have a Talos, but have ordered a Triton and Typhon (Was supposed to be here yesterday - its been delayed until the NY) - I ordered the ETRON Sigma HC to run from the wall into the Triton thinking that was best, then running 3 Alpha HC's to 2 x Woo Audio 234's & a Light Harmonic DaVinci, bit concerned that maybe I stuffed up and should have ordered a alpha digital for the DAC?
I generally find an HC cord to be overkill on a DAC or on any source.
Alpha-digital on DAC, yes.
Should be Sigma Digital even better for DAC.
IMO, Law of Diminishing Returns. Better to $pend on music. After all, that's what it's all about, eh?
