The answer to your question is quite simple, and I have mentioned it a number of times in past, my personalized Remastering process settings are optimized for the music that I listen to for “enjoyment” and not for system evaluations. I listen to extremely fast music and it benefits from my settings. I don’t listen to classical music, but I can obviously appreciate how the extra wood is beneficial there.
Regarding the Remastering process, yes there are a number of great high-end mastering analog hardware tools out there that can be used to achieve similar results, but don’t be mistaken these results came about because of my knowledge and not the tools. I’m planning to develop a second Remastering process chain and will be using completely different analog mastering tools. The tools are actionable but without the knowledge it is a mess waiting to happen.
Here is something else on my Remastering process to think about, I timed myself and it only took me a total of four (4) minutes to adjust the Remastering process settings to develop and achieve the “Wood Edition” settings. The Remastering process is the greatest thing for “system” sound shaping that I know of. I had done this with my large mastering systems in the past but never with such a small and concise chain and solution. Again, I must give partial credit to HQPLAYER for providing the best sounding source to the Remastering process.
Just like I was able to add “Wood”, I can custom tailor a solution for other systems, if they are capable of the desired outcome, and system owners.
The Remastering process is truly powerful and something very special. To get that wood sound cost me four (4) minutes of my time and no new components or cables, grounding boxes, special cartridges, arms, time-aligned speakers, special stands, bases & shelves, exotic materials, bespoke engineered acoustically treated room, no tube rolling, no magic fuses, no magnetic drives, no active suspensions, special electrical power installation & conditioning……… you get the picture!
With my Remastering process, you can make your system sound the way that you always wanted it to sound like or dreamed of! And it has the flexibility to adjust if your ideal sound objectives change!
