UPDATE
Old Thread in this forum 11 months ago:
http://www.whatsbestforum.com/showthread.php?12796-Antenna-s-VHF-UHF-HDTV-and-FM
I'm doing a cut & paste of another thread in another forum - see below, it's been a little bit helpful.
http://forum.tvfool.com/showthread.php?t=15018
Just under a year ago I installed a HD Stacker antenna from Denny's, eave mount with standard 5-foot mast/pole kit. It barely cleared the 10/12 pitch roof but I got many more stations than basic cable and a lot better picture/sound too.
Link to kit:
http://store03.prostores.com/servle...re/the-222/HD-Stacker-Installation-Kit/Detail
This weekend I decided to install a 10-foot pole I picked up earlier in the year. The only change needed was a longer RG6 coaxial cable coming from the outdoor 300/75 ohm transformer strapped to the antenna to the end peak/eave bottom of pole located Winegard LNA 200 preamplifier.
PROBLEM: I have no signal.
Dumb Moves:
While removing the old cable from the 300/75 ohm transformer, the small lead wires to the antenna snapped off the binding posts - frayed by weather I suppose.
Compound Problem: one of the terminal bolts which the outdoor 300/75 ohm transformer ties into spins. I had over tighten this last year but everything worked. I used long nose vice grips to lock the bolt in place at the top and bottom points, then it was easy to turn the locking nut off.
Solutions -1 & 2:
I soldered longer 300 ohm lead wires and clips on the transformer run, still no signal. I put new clips directly on the 300 ohm wires, still no signal. Then I bought a new $6.00 Radio Shack 300/75 ohm outdoor transformer with some nice looking lead wires, still no signal.
Solutions - 3 & 4
I tried a variety of RG6 coaxial cable runs (antenna to preamp), all tested out fine on the Multi-Meter. In fact I put my Multi-Meter everyplace I thought a signal should be passing and got good continuity readings including the antenna posts themselves.
Solution - 5
I disconnected and reconnected the remote power supply in my basement for the pre-amp to no effect, still no signal.
Solution - 6
Tried other TV's in the house, tried searching for new signal though the TV, still no signal.
Next time your think that you can do a little better, and maybe reach for the stars, remember this story. Sometimes sleeping dogs should be left to lay.
I'm open to suggestions on what to try next.
I'd hate to think the preamp just happened to die because it was moved a little. It was not banged or dropped, just dangled safely from the eave. All connections to it have been redone to insure they have not loosened up.
I'm stumped.
I just tried by-passing the preamp, still no signal.
I just tried changing the cable (12-foot presealed) from the preamp to the 75/300 ohm outdoor transformer, still no signal.
Guy at the local hardware store was supportive, and said there is nothing inside the antenna connection where the transformer hooks up like a soldered connection, it's basically what you see is what it is - all external.
Just tried a SnapAV 12 foot RG6 coaxial cable which a local audio store put together for me with some nice terminations. Placed between the outdoor preamp and the 300/75 ohm balun. Still no luck with getting a signal.
To clarify on the "by-pass" procedure, I physically disconnected the preamp, put a male to male coupler on, and connected the antenna cable to the cable going into the house via the coupler.
I did this with the "power inserter" in the basement still on (because I forgot all about it), and the splitter in the basement still in-line with all the TV's hooked up to it. I thought at least a few of the stronger signals should get through, but nothing did.
I will unplug the "power inserter" when trying a new by-pass test later today (weather permitting).
If the by-pass later today works, I will replace the 300/75 balun (again) when installing a new preamp and line inserter power supply.
I unplugged the inserter preamp power unit in the basement, watched the little green light fade away.
I then went up the ladder to the preamp on the pole and using a male/male coupler tied the in and out together, thereby by-passing the preamp.
Still no signal.
There is a chance the replacement 300/75 balun from Radio Shack was burnt out according to Stereocraig's comment if used in the previous powered up by-pass attempt. I frankly don't recall if that new unit was in place during that test, or the old one, so I'm off to the store to spend another six dollars.
EDIT
New cable and transformer made no difference, by-pass with power down also still no signal.
I bit the bullet and purchased another Winegard LNA 200 preamplifier for $55.
Installed it and the new power supply, still no signal.
Then the one connection which I've never messed with, the one which connects the preamp to the cable going into the house I redid, most likely the best job of one I've ever done, still no signal. And yes I took the precaution of unplugging the power supply in the basement before and after each change and or work done.
How can an antenna go bad?
That's the only thing I'm really left with isn't it?
I tried calling Denny's TV twice and sent a detailed email................that was days ago and no response.
I'll try again today. (just a recording again)
My only idea left is to by-pass the recommended connection to the antenna, and try one of the other contact points. I would suspect a loss of some signal by abandoning the lower array, but if I get any signal at all at this point I'll be somewhat relieved.
Still no one picking up the phone at Denny's, this is typically the case sad to say.
This is my latest idea of a "by-pass".
That one connection spins upon tightening, but I have it tight.
The binding post above it on the next tier connects it all together via "u" shaped metal each side of the main square tube.
I tried that different type of by-pass or TV antenna connection point...........still no signal.
I redid a bunch of connections on the antenna plus double checked the in-line ones too, to no affect.
I positioned the antenna to the original NE vector just in case there was an anomaly true east.
Photos of the failed experiment.
http://s184.photobucket.com/user/kach22i/library/MISC?sort=3&page=1
Before:
After:
Different angle:
When I was done finding out that there was still no signal I switched it all back to the original set up.
By any chance, should I unplug my TV and power it down to reset it? All I'm thinking is that perhaps once I stopped the signal by moving to a taller pole/mast, some recognition software glitch ensued.
I unplugged the TV, made no difference, still no signal.
I have not done a fresh direct wire from antenna to TV with no ground block, boosters/preamp or splitters in the path.
Is that the next step, or have I missed something?
Link to kit:
Dumb Moves:
Solutions -1 & 2:
Solutions - 3 & 4
Solution - 5
Solution - 6
I'm stumped.
Still no signal.
EDIT
Before:
After:
Different angle:
