Where do you place your equipment???
Loheswaran
436
101
273
or behind, for the sources:
and with the amplification up front, near the loudspeakers:
... I wish...
loki1957
131
97
935
66
Santa Fe NM
I'm fortunate enough to be able to put my racks to the side totally out of the soundstage. They sit in a bump out in the room. The amps do sit behind and between the speakers.
XCop5089
124
96
260
Winchester, UK
My system set-up is dictated by the dimensions of my lounge (18'3" W x 22' L x 8' H) as I do not have the luxury of a dedicated listening room!
I am fortunate in having a moderately large lounge (by UK standards) which allows me to have the speaker drive unit centres 5' from each side wall and placed well into the room.
I agree with those who advocate nothing between the speakers but amps (and room tuning - in my case DAAD 4/3/2's) and equipment racks are placed along a side wall, albeit closer to the left speaker than I would have preferred! However, my hi fi system does reside in a space which is used as a lounge/sitting room, so domestic harmony prevails and I have to make the best of what is available.
On the plus side, I enjoy listening to my music without worrying about the equipment and stage width, depth and dynamics are represented very well!
fullsizeoutput_8c5 by Steve Coward, on Flickr
XCop5089
124
96
260
Winchester, UK
Reactions: asiufy
XCop5089
124
96
260
Winchester, UK
Reactions: asiufy
tmallin
WBF Technical Expert
May 19, 2010
970
387
1,625
71
Chicagoland
There are at least three factors which should come into play in deciding where to put your electronics in relation to your speakers, assuming that such a choice has audible consequences at all. Do you believe that vibration from the sound from the speakers affects the sound quality of what you hear from the speakers? Do you believe that the length of cables has an impact on sound quality? Do you believe that sound reflections from equipment faceplates affect the quality of the sound you hear?
Even if you answer "yes" to all three questions, the importance of each factor may figure into where the best spots for things are. By far the most sonically important factor in room set up is to place the speakers and listener in the best spots. The placement of the electronics should be worked around that choice. Basic room acoustics trumps all these other secondary or terciary sonic effects.
And even the most gorgeous room (as in Northstar's pictures) can have badly chosen listener and speaker locations or badly chosen basic dimensional ratios. The pictures of that room show at least two immediate problems. First, the subtended angle between the two speakers from the chosen listening seat is quite obviously less than 60 degrees. Sixty degrees is the standard minimum for intended left-right stereo separation. The best microphone arrays, those involving quasi-coincident main microphones (e.g., Blumlein, M-S, ORTF, X-Y) demand playback with about 90 degrees of left-right separation. Only the stereo recordings made with two or three widely spaced omnidirectional mikes (e.g., Telarc, Chandos, Everest, Mercury, etc.) sound decent with less than 60 degrees separation. Some 'philes choose narrow separation as a way to help tame the overly bright high end of their chosen speakers; narrow separation can help since sources heard from closer to straight ahead sound less trebly than sources heard from significant angles to in front of the head. They sacrifice stereo for tonal balance. Choose better speakers or use equalization, I say.
Another problem evident in the Northstar pictures is that the listening position is both too close to the back wall for smoothest bass response and too far from the speakers. The listener will be hearing too much second venue effect from the listening room at that distance. Again, 'philes sometimes choose such an arrangement since their chosen speakers sound incoherent from closer distances--undoubtedly a problem with huge tower speakers with drivers covering various ranges strung out for three or more feet along a vertical baffle. Such an arrangement probably will sound incoherent from closer in. Again, choose a different speaker, I say.
But I digress. Once you arrange the listening seat and chosen speakers optimal separation, less second venue effect, and good interaction with the room's bass modes (try one of the arrangements on this page; I'm fond of the Rule of Thirds 29% Version), where should the electronics be?
Placing your electronics (other than perhaps the amps) in an adjacent room or soundproofed closet may well be ideal if it is practical for your situation. One element of practicality is whether remote control to that second room is available from the listening seat. With a system using only digital sources controlled through a smartphone or tablet connected to your home's wi-fi network, it may well be practical. A radio frequency (as opposed to infrared) analog remote control might also be practical for such an arrangement. For analog LP playback, it's probably not practical, or at least not very convenient. Do you want to go that far to start or change a record and then miss the beginning before you get back to your listening chair? Such a solution does offer the lowest vibration-induced interference as well as essentially zero reflection of sound from the audio electronics faceplates. It may, however, lengthen the audio cables, at least the link from preamp to amps, or from amps to speakers. Most listeners who hear the sound of cables would agree that longer cables of any particular type, regardless of quality, generally do not sound as good as shorter cables of the same type. Longer cables are also more expensive than shorter ones.
Putting the electronics behind the listener also creates as situation where at least the preamp-to-amp cables or the speakers cables are quite long in order to reach the speaker area. This placement also puts the electronics in an area which, if near the wall behind the listener, is also an area of maximum bass vibration. The Northstar pictures shows what could be an old Cello Palette Preamp or Audio Palette on the angled Cello Audio Cart. While this is very convenient, it also necessitates multiple long runs of cabling from the equipment rack to the control center which is at the listener's fingertips. Maximally convenient for adjusting volume and EQ, but expensive and potentially sonically detrimental from a cabling standpoint.
In my experience, electronics should definitely not be placed in a spot where specular reflections of sound from the speakers can reach the listener's ears. Use a small flat mirror to determine whether you can see the reflection of any part of either speaker reflected in a mirror placed flush with the equipment faceplate. If so, that faceplate will reflect sound to the listening seat. Such reflections certainly are audible and in my experience are sonically detrimental. Thus, there will be certain spots along the side walls of the room where equipment should not be placed from a reflection standpoint. Of course, such spots may be located in spots where bass vibration is less, a plus.
Usually, if your speakers are separated by the recommended 60 degrees or more as viewed from the listening seat, there will be an area midway between the speakers where you can place a vertical rack without the rack being in the specular reflection zone. Placing equipment on such a rack can keep all your cables as short as possible. And if you keep the rack fairly low, lower than tweeter height, my experience has been that imaging and staging will not be adversely affected. Alternatively, you can mount equipment on a few "amp stand" type racks, directly on carpet, or supported from hardwood by footers of your choice. Keeping all the equipment that low minimizes reflections from their faceplates, and you can still usually arrange things so as to keep all the cables fairly short. If the equipment is remote controllable, such can even be eminently practical; it remote control is not practical, it could provide some exercise until your knees get tired of the routine. However, if the equipment is near the wall behind the speakers, it typically will be located in an area of higher bass vibrations, a negative.
Generalizing from my experience, I'd say that for analog turntable front ends, minimizing vibration is the most important consideration. Acoustic feedback, especially at subsonic frequencies and DC (from footfalls) can cause even the highest-end turntable set up to actually skip out of the groove, much less produce a bit of extra distortion. Thus, placement of such equipment somewhere along the side wall out of a specular reflection area is best. If the side wall is a bearing wall, such placement is even better. Placement of the turntable near a bearing wall is especially important in a room with wooden floors to minimize floor bounce. Just keep the distance between turntable and phono preamp to an absolute minimum. Such cabling should never exceed four feet in length.
Again generalizing from my experience, for systems with just digital sources, vibration really doesn't seem to be such a crucial consideration, especially if you are using digital files through a network or streaming files from the internet as your primary sources, rather than spinning CDs or SACDs. Good equipment racks and footers can handle vibrational problems well enough for such systems, I've found. For such systems, I think putting the electronics between the speakers on a short rack or very near the floor is the best way to both keep cabling short and keep reflections from the electronics away from the listening area. For me it also creates a visual symmetry which is pleasing and works in harmony with left/right stereo spread and center fill/focus.
toddrhodes
28
32
78
44
I've had three layouts thus far in my room. My room is unfortunately small, but I work with what I have. That said, my 2nd layout, which was predominant for most of the time I've had my dedicated room, situated gear and a cabinet holding vinyl between my speakers. Based on this thread I took a shot today and rearranged the whole thing. Took some clever thinking but I made it work to get that shelf out from between the speakers and off to the side. There are numerous benefits to this - it uses the space in the room more efficiently, it gives me more subwoofer placement flexibility, it isolates sensitive sources from vibration, and frankly it just looks a lot better.
I've noticed several acoustic benefits from this new arrangements and outside of knowing now I need some treatment on the now-exposed front wall of my room, I've not heard any drawbacks so far. I'm getting a more open and believable soundstage, speakers seem to have completely disappeared now which before they were invisible on some things, but not others. Due to cleaning up cabling in the process, I've decreased some noise in the system (I'd never heard my air purifier running between tracks prior, heard it tonight even thought it's very quiet), details within the recording are more profound and easier to locate in the image, and so forth. Also, I think since that front wall is more exposed now, the system is louder than it was which is convenient because even just a week ago, I felt like either a tube was starting to go or my amp (Odyssey) was needing a bias adjustment or something, because I was digging way into the volume control to get decent SPL, and I confirmed that using two different SPL mics.
Anyway, rambling now, thanks for the thread, it inspired me to find some free performance in my system!
Reactions: XCop5089
Al M.
8,785
4,543
1,213
Greater Boston
Fantastic post, thanks.
Folsom
6,029
1,501
550
Eastern WA
Off to the side. But often I wish the TT was on the side of my chair so I could stay seated to flip.
Out of the room would probably drive me nuts - and has diminishing returns if any.
Uk Paul
516
183
955
UK
All of my gear is on the long side wall, not because of sonics though, but because I don't like to sit and look at it when playing music even though it is a nice looking set up.
Uk Paul
516
183
955
UK
Very nice set up Xcop, and room.. I see you use a sub with the CR1's, and imagine it all sounds truly excellent. We used CR1's at Whittlebury one year, I had them here for a while too, and found them to be exquisite in all but the low bass, so using a sub is (for me) a wise choice.
Rgds,
Paul
Reactions: XCop5089
spiritofmusic
14,625
5,432
1,278
E. England
Ok, I'm sold on the concept of moving my gear to the side wall alongside me. Esp my floor sited tt which currently is mid spkrs which run floor firing subs.
However if I want to keep my monos on side wall too, this would necessitate me running longer spkr cbls, 30', or if I keep the monos w the spkrs, run longer ICs, 20' (bearing in mind I can only use RCA, not XLR).
How exactly do I decide the trade off between the unarguable benefits of moving my gear, esp tt, from out between my spkrs, versus potential signal losses of going from 5' to 30' on spkr cbls, or 5' to 20' on RCA ICs?
Folsom
6,029
1,501
550
Eastern WA
You won't have any real signal loss. You'd have to be in excess of 50 feet for IC's, and even then when you notice, well, harder to say. Well, unless your preamp is total garbage.
spiritofmusic
14,625
5,432
1,278
E. England
Folsom, I thought the restriction on RCAs was length of cable?
Ie to go to 20-30' you'd need XLR by definition?
Folsom
6,029
1,501
550
Eastern WA
50 foot is typical “limit”. And the restriction has a lot to do with what’s driving them. Bad IC properties could cause some loss of fidelity. The exposure to RF is the reason to go to XLR, but it’s a moot point if both ends are not grounded, or the shield isn’t there. It wouldn’t be a surprise if many audiophiles liked the result of long cables that far exceed 50’. You don’t find a lot of properly shielded XLR setups.
Some manufacturers claim that a constant impedance is needed for long runs. That would be true if it were RF (digital may qualify, not sure). But at audio levels it’s 100% not possible because impedance changes from frequency to frequency a lot. IE it’s just marketing.
So long as a preamp can drive the IC’s, the signal will do well. The IC would need a pretty silly amount of capacitance, inductance, or resistance to start seeing loss.
I am not making the case it is ideal, just that the detriment difference between 3’ and 50’ isn’t as drastic as people may fear. It probably stems from asking someone who knows, about what lengths are good. They can answer “doesn’t really matter” or try to give an honest answer for the best possible scenerio - but forget to tell you that you may be talking about a thousands of a percent difference.
spiritofmusic
14,625
5,432
1,278
E. England
And so the benefit of clearing gear from btwn the spkrs remains?
Folsom
6,029
1,501
550
Eastern WA
Speakers that aren't highly directional send a lot of sound waves backwards. The sound wraps around the speaker. When it hits the gear between them it can reflect earlier, with lots of diffraction. If it's too early it causes smearing. And diffraction often sounds bad no matter the timing.
spiritofmusic
14,625
5,432
1,278
E. England
You'd advise longer interconnects than spkr cbls?
Folsom
6,029
1,501
550
Eastern WA
Many people saying longer IC's. I think whatever is convenient for you will be just fine. No one has really shown a bit of speaker cable to cause a problem in such small settings.
spiritofmusic
14,625
5,432
1,278
E. England
Well Folsom, alongside additional room treatments, this could be my major system preoccupation for 2019. Moving gear to side wall, esp to get my floor sited tt away from Zu floor firing subs.
