Which SUT for Miyajima Saboten L
moniker
9
6
5
71
Lotusland
I recently bought a Saboten L and I can’t decide which SUT is likely to sound best with it. It’s 16 ohm and .23mv output. Has anyone got a recommendation? My budget is about $2500. I’ve been considering the EAR MC4, the Tango MCT-999, Audience EMT (Hommage is a bit steep for me), or a used Denon AU-S1 or other Denon.
Of course, Miyajima makes the KSW but again, even though it might be an obvious choice it’s a bit expensive.
I’m open to suggestions of any vintage outliers I don’t know about.
Thanks and keep on spinnin’.
moniker
9
6
5
71
Lotusland
My mistake: I meant Auditorium A23 EMT version. I think this one might use Haufe transformers. I’ve searched but they don’t seem to be available.
beaur
Fleetwood Sound
Oct 12, 2011
460
166
950
60
Brooklyn
Well, the Miyajima is a great match. A bit above your budget but you could get in touch with EMIA and they can make a custom one specific for the Saboten. If you want a great bang for the buck check out Lounge Audio.
Good luck
Beau
