I guess it’s time to come out of the SS closet. I have been using tube gear exclusively since around 1985 (preamps and power amps) and was using tube preamps exclusively for several years before that. So basically for the last 27 years I have been listening to tubes in my system. That’s over a quarter century of tube listening. During that time I had convinced myself of the superiority of tubes and would basically turn my nose up at the sight of SS gear.
And then something snapped, and it snapped a few times before it finally broke. And the catalyst for the ‘snap’ was a combination of a very low ambient noise level in my listening room coupled with the noise of tube phono stages, tube preamps, and tube power amps mixed in with the inherent problems of output tubes being eaten and small signal tubes going noisy or should I say nosier and along for the ride, their first cousin named ‘Microphonic.’ They all combined together for a potent toxic mix.
One of the times it ‘snapped’ was when my ARV VT-100 MKII started acting squirrely and making a strange low frequency oscillation sound that I thought was going to take out my subs and possibly the sub amps. I was going to go ahead and buy new tubes and set the bias until I read the bias procedure and saw it was straight out of Chapter 1 of Dante’s Inferno. There is a reason Uncle Kevin from Upscale Audio refuses to sell tubes for any VT-100 series amp.
Before I owned the VT-100 MKII amp I had stuck my toes in SS waters when I purchased a Pass Labs X-250 amp. The X-250 was a disaster in my system. It sounded more like a 25 watt amp. I was glad to get back to tubes when I bought the ARC VT-100 MKII. Next up to bat was the Jadis Defy 7 MKII which I found the looks striking and the midrange glorious. It also gloriously munched on my 6550 output tubes and every time it eats a 6550, it takes out the cathode fuse and sometimes the cathode resistor. I could go on and on about the nonsense you have to put up with if you own a Defy 7 (and I have talked about the nonsense in the past).
Sometime before my last Defy 7 problem I had taken my Teac R2R to a local repair shop. While I was in there I eyeballed a Phase Linear 400 Series 2 amp. The owner explained that he had completely gone through it, replaced the power supply caps with higher value caps, and it was working perfectly. I bought it as a backup knowing that with tube amps, you need a backup. So when the Jadis munched another 6550 and took out a cathode resistor with it and I was waiting for Brooks Berdan to ship me a replacement resistor, I installed the Phase Linear amp in my system.
So now I’m a little shocked at what I’m hearing and not hearing. There is a quality to the bass reproduction from 20 Hz to 160 Hz (the bottom three octaves) that tube amps can dream about, but can never really achieve. Let’s face reality: tube amps struggle with both accurate bass and accurate high frequencies. It’s the nature of the beast when dealing with tubes and output transformers. Tubes are inherently high impedance/low current devices. Output transformers help convert the high impedance and low current to a lower impedance and higher current, but it still doesn’t come close to what a SS output stage can do.
Added in with the low current that output tubes have is the low dampening factor. Even though some tube companies (think ARC) try to compensate for this by building massive capacitor banks for energy storage, they still can’t get around the low dampening factor. A tube amp is never going to have the iron fisted control over your woofers that SS has.
High frequencies bring on another set of issues with tube amps. Because the output impedance of a tube amp is so high, there is always an interaction between the changing impedance of the loudspeaker across the frequency bandwidth and how that affects the highs. We can all kid ourselves and say it doesn’t really matter and the highs sound just fine. I know I did for over 25 years. But when you seriously listen to a great SS amp and you still want to cling to that line, you have crossed over into the land of make-believe.
And what about that glorious tube midrange? The midrange of tube amps is about the only thing they come close to getting right because they can’t get the bass or high frequencies right for reasons I stated above. And we hear all types of adjectives used to describe the glories of tube midrange, but I seriously think that any harmonics you hear through a tube amp in the midrange that you find lacking in a great SS amp are just low levels of harmonic distortion being added to the signal that is pleasing to the ear. You can come up with your own counter-theories like “Oh no, tube amps are just letting you hear the harmonics that SS strips out from the signal. Uh-huh. The only difference between that statement and a fairy tale is that it didn’t start off by saying “Once upon a time…”
As for tube phono sections and tube line stages, don’t even get me started. Here is where the low transconductance of tubes becomes their own worst enemy with regards to noise. If you want the absolute lowest noise you can achieve in your system and thereby increase the purity of the signal by eliminating distortions, you aren’t going to get there with tubes. Tube phono stages and line stages will add noise to your signal that will ride right along all the way to the power amp. And if you are using a pure tube preamp to amplify low output MC cartridges, you are adding lots of noise that is being amplified by both the line stage and power amp.
I had over $5K invested in my pure tube Counterpoint SA-5.1 preamp with all of the upgrades and it wasn’t all that long ago that I thought it was the bomb. While it was off for its last round of upgrades I bought a Yamaha C2a to tide me over. I have written all of this before. I was embarrassed how badly the C2a bettered my Counterpoint.
Fast forward to the near present: While my Krell KSA-250 was back at the factory for what I thought was going to be a repair and shipment off to its new owner, I decided to buy yet another tube amp and tube preamp. I bought the ARC VS-115 and the ARC LS-17. I have written a mini-review of the VS-115 and the LS-17. The VS115 is the best sounding tube amp I have ever owned. It has the best tube bass I have ever heard. But it’s certainly not the best amp I have owned or even close to the best bass that I have heard. The LS-17 was the second one that I have owned and it sounded just as bad as the first one I owned. But the bottom line is that the VS115 is not capable of the performance of a great SS amp in my experience. And I hate to say this, but it’s not even capable of the performance of a really good SS amp.
I am officially done with the ‘glories’ of tube preamps and power amps. If the highest fidelity to the source is truly your goal, you are not going to get there with tubes. You will be adding measurable amounts of distortion and noise to your signal at every step of your tube chain. It’s time to put the VS115 up for sale so it can find a new owner who can revel in the tube magic and glory. For once and for all, I think I have finally broken my addiction to vacuum tubes. Out of all the adjectives you can use to describe the magical tube sound, the one adjective that doesn’t apply is ‘accurate.’ Like I said in a thread I started some time back, it really is all a preference.
Except for most of cherished recordings were recorded with tube electronics.
You're welcome to hear the new cj electronics, Doshi phono and let me know if you feel the same way.
