...we're all looking for a protractor and a "goose-neck" to solve those items.Then all that's left is my lack of experience and my laziness.
Please don’t get me wrong I prefer vinyl over digital and agree with you but vinyl contains conversion too. Electrical signal captured by microphones is converted to motion or vibration by being etched into the grooves during cutting process. The same applies to tape but this time it is converted to magnetic field. So, there is a conversion on all formats but digital causes fatigue for me while analog counterparts don’t.
My apologies to those whose feathers I ruffled.
I hear you about maintaining a well-dialed in LP set up. As I've aged my eyes have lost more acuity than most, and it feels just about impossible for me to dial in a cartridge with a protractor. In my 40's I was quite confident in it; now, subcontracting seems appropriate. I am looking for a good goosenecked USB scope to aid my eyes. That likely would make all the difference.
Hi 'tima',Along with a few small bright flashlights, I find this magnifier quite helpful ...
Donegan DA-S1 OptiVISOR -- has 6 glass lenses, 1.5x to 3.5x
Hi 'tima',
Which interchangeable lens do you use the most with the Donegan DA-S1 OPtiVISOR kit ?
I thought the conversion started at the microphone with sound converted to electricity. I suppose you could take this back to breath and muscle converting to sound or even further back if you like. Conservation of energy and all that. I don't think conversion from one form of energy to another is what distinquishes analog from digital.
Correct me if I get this wrong ... the distinction between analog and digital is that the former is continuous and the latter is discontinuous.
Perhaps this can be described in terms of the sampling rate or the sampling unit. Can one say that analog has a sampling rate of 1?
Whereas digital has a sampling rate of ... well pick your frequency format ... I can't keep track of how many of those there are ... some group of bits across time.
I agree with you.I thought the conversion started at the microphone with sound converted to electricity. I suppose you could take this back to breath and muscle converting to sound or even further back if you like. Conservation of energy and all that. I don't think conversion from one form of energy to another is what distinquishes analog from digital.
Correct me if I get this wrong ... the distinction between analog and digital is that the former is continuous and the latter is discontinuous. Perhaps this can be described in terms of the sampling rate or the sampling unit. Can one say that analog has a sampling rate of 1? Whereas digital has a sampling rate of ... well pick your frequency format ... I can't keep track of how many of those there are ... some group of bits across time.
I agree with you.
Digital involves a kind of discontinuous conversion — sampling a waveform — while analog is continuous. However, once a digital signal is converted back to analog, it becomes continuous again.
With my previous post, I was trying to draw attention to the fact that all mediums involve some kind of conversion, one way or another. Whether one is better or more “continuous” is another discussion. At the end of the day, analog mediums also convert the electrical audio signal — to magnetic flux (tape) or physical engravings (vinyl). Personally, I prefer the type of conversion that analog mediums use over digital conversion.
Personal preferences aside, the real pertinent question is not whether one conversion involves a step of discontinuity or not.
The real question is which conversion introduces quantitatively more, and/or more psychoacoustically relevant, distortion through the entire process from beginning to end. People may have different opinions on that matter, but that is the real question.
Your observation that digital in the step back to analog becomes continuous again hits the crux of the matter: Nobody listens to digital, we all listen to analog wave forms.
The real question is which conversion introduces quantitatively more, and/or more psychoacoustically relevant, distortion (i.e., deviation from the original music signal) through the entire process from beginning to end. People may have different opinions on that matter, but that is the real question.
coming from one who is as equally committed to digital as analog, empirically @mtermur 's and @tima 's perspective fits exactly into my experience.equally It's not a question. Pointing out the continuity and discontinuity of the source signal is a description of the fundamental difference between analog and digital. Humpty Dumpty. Doesn't have anything to do with what one prefers.
" Technically the NASA Mars lander surpasses all audio gear "Technically current top digital surpasses analog - I think no one will question it.
I will remember you saying this the next time you say 'most modern records are digitally recorded'.
da conversion is like trying to reglue a sliced salamiYour observation that digital in the step back to analog becomes continuous again hits the crux of the matter: Nobody listens to digital, we all listen to analog wave forms.
But I though you compared 5 pop records from 70s and found that yesteryear vinyl was not as good as modern.most modern vinyl is not the all-analog experience of yesteryear?
What does one have to do with the other? And why does it anger you when someone points out that fact, and that therefore most modern vinyl is not the all-analog experience of yesteryear?
The real question in this regard is which conversion introduces quantitatively more, and/or more psychoacoustically relevant, distortion (i.e., deviation from the analog waveform of the original music signal) at the end of the process. People may have different opinions on that matter, but that is the real question.
