Hi Asiufy , must admit that my system is not ideal for instant compares , with its comprehensive grounding schemes constantly chopping and changing , unplugging and re plugging the earth cables does disturb the equilibrium . It takes a while to settle back . Having said that the Origine was subjected to the same the first time it was inserted , it had settling time the second time Ked visited and sounded even better . I think my Stage 3 Leviathan power cords are pretty up to it , so don't think can point any fingers there . Possibly the AES cable was a mismatch , hope to investigate when time permits . Having heard the Formula elsewhere , would be hard to classify it as full bodied. Seasons best to you .
P.S. Also do take into account that mostly all observations made were using un amplified , highly complex big scores and not girl with guitar type music.
To my ears almost all digital sources do exhibit digititus.
Yes his home system wasn't optimised to sound good with Neodio
You keep saying this but what does that mean really? The amps were wrong? The preamp was wrong? The speakers? The footers!!!???
Ked, as an avowed cdp guy, the Origine is the piece of gear in your visit of most interest to me. Can you elaborate in a bit more detail what it did right that the others failed to quite match?
I believe it’s availabile now 40% cheaper factory direct from Neodio, which puts it €15-20k?
Well that makes it reasonable value in the marketplace (as such for a cdp), my Tentation is €10k, Autographe is €15k. Not much else in the “organic” SQ category for CDPs at these prices.
Don't have a comment on the compare, but a $35k dac that has this for the insides?
It means the Trinity pre, cables, grounding, were all connected to the incumbent Trinity dac. Voicing of overall system was for Trinity. Yet, the Neodio came out cold and was better.
All you see doing Marc, is extrapolating how you go to unfamiliar systems and don't isolate components. Regarding unfamiliar room and ancillaries, the owner is part of the shootout validating the results (as is another regular to the room friend of his). You are a random guy over the internet who hasn't been there, done that, voicing opinions
Hey Ked, what is the internet for if it isn’t voicing opinions ?
