Great info Amir, I need to go back and mention that in the article. The consumer-grade Weller station I’m using now is I think 10 years old, or maybe even older. I haven’t had any problems with it but I sure hope Weller’s “time” expired sometime after I purchased it!On soldering irons/stations, Weller's time has come and gone. The new "standard" among hobbyists is the Japanese brand, Hakko with this model (FX-888D) being most popular now:
It is a joy to use despite its funny looks. My equiv. Weller has already failed with rusted PC board and bad main IC. They really cheapened the brand in later years.
Y’know, you’re the first one who’s ever claimed they did that after reading that article. Cool!After reading your tutorial, I ordered ALL my welding supplies from Amazon. I bought a Weller WES51 and a set of Weller tips.
What temperature do you recommend for board work?
Nope, never have done that. I prefer shielded cable, so that pretty much precludes any DIY.Wayne, thank you so much for the great learning.
I would like to know if apart from terminating, did you ever made your own cables? That is threading the actual wire through sleeves.
Regards,
Wayne A. Pflughaupt
Thanks but never left. I will never forget my rootsWelcome to the working class! Perhaps you can ask the optimum tip temperature to the solder manufacturer - that is different from the usually specified melting temperature.
My vintage Weller was put in service today - time to keep an old promise of building a pair of Mogami XLR cables for a friend. Fortunately I am still able to get cheap tips from the german eBay!
Thanks!I have the WES51 as well, and the range I use is 45-50 for soldering, 50-60 to melt and unsolder; but it really depends on the solder itself, and have been using those premium ones (forget the names) with lower melting temperatures.
Amazing write up Wayne. Thank you for your time and effort. I have made the thread a sticky. Any more goodies in your bag of "how to" as this one is really remarkable
yep, currently restoring a few turntable/ps/motors ...
Just went through this excellent guide on making audio cables.
Soldering is technique and an art - each artisan has its way of doing it. I learned how to solder from an old technician who used to build cables, electronics and wire chambers at CERN in the 70's.
He did it in a different way - I still keep his five basic rules: 1. Solder adhesion should give electrical conductibility, not mechanical support, the objects should be self supported without solder. 2. Extreme cleanness and tidiness of the two objects being soldered and the soldering tip. 3. Absolute mechanical stability during the soldering time and cooling - he used two mini-vices to keep the wire and plug in place . 4. The soldering iron should contact the three objects - wire, plug and solder - simultaneously for the soldering time. Pre-tinning was not allowed and we had to carry the soldering in one time, if re-soldering was needed we put some new flux! 5. High quality solder with a good flux - solder should flow almost like water, wetting the elements perfectly and stay bright and nice looking!
For a good soldering the iron should have power enough - 50W minimum with fast thermostatic control - you need a constant temperature with a good capacity of supplying heat. I got an Weller - curiously most time we see articles on visits to cable manufacturers we see the Weller's on the benches!
My worst experience - trying soldering Cello cables Litz wire without the proper tools. Even the thick outer braid is made with enameled wire!
Now that made for fascinating reading, because I was taught in exactly the same way, in Switzerland no less! Pre tinning was not allowed, metal had to touch metal, tiniest amount of solder applied swiftly and flowing hot to be later inspected to be bright and shiny. In addition, with the job done, a small touch of hot glue from a pistol was added to prevent vibration and add stability. This master craftman maintained, that the sound of a cable was mainly based on the quality of the solder joint and he scoffed at the " miserable quality" of those joints in expensive high end cables.
I have never heard of this practice. Indeed the opposite, pre-tinning is highly recommended and mandatory in the case of work done for the US government. Here is a sample from NASA:Now that made for fascinating reading, because I was taught in exactly the same way, in Switzerland no less! Pre tinning was not allowed, metal had to touch metal, tiniest amount of solder applied swiftly and flowing hot to be later inspected to be bright and shiny.
"7.2.5 Tinning of Conductors. The portion of stranded or solid conductors or part leads that will
eventually become a part of the finished solder connection shall be tinned with solder and
cleaned prior to attachment (Requirement). "
I can't tell you how many times I have skipped this step, proceed with the soldering only to have the wire simply pull out from under the solder! Visually you thought you had a connection but there was no adhesion to the wire itself. Just a mile mechanical force keeping the wire under the solder. Wires such as Litz almost require this practice as they are a pain to solder to and you can easily think you have adhesion when you don't. Pre-soldering solve this as you can see if the solder has taken hold or not.
For beginners getting into soldering, it would be my strongest recommendation to pre-tin/pre-solder your wires first before making the final connection.
I also press the joint together with a screwdriver before the solder freezes to make sure there is good contact. This takes some coordination and speed but is possible.
This is correct imo, and is certainly a requirement for litz wire, which I use quite a bit... I also press the joint together with a screwdriver before the solder freezes to make sure there is good contact. This takes some coordination and speed but is possible.
I think it's also the case that set-screws sound better than any soldered joint. Most of the connectors I use are set-screw or clamp connections but despite that the WBT 0102 are still the best RCA plug even though they use soldered connections.
Dave wouldn't using a screwdriver tip act like a heatsink on the solder joint? Could this cause a cold solder joint?
