Golden Gate 2 Reactions
abeidrov
VIP Donor
Dec 17, 2015
706
341
443
Moscow
What does you spec sheet say? Does it give the FW number? if not just contact Lukasz about reflashing. its fairly easy but you need to open the chassis and use a windows computer.
The spec sheet says 2002b. So it should work with Linux.
abeidrov
VIP Donor
Dec 17, 2015
706
341
443
Moscow
abeidrov
VIP Donor
Dec 17, 2015
706
341
443
Moscow
Yes, USB from EX, LAN between CX and EX. Before I used USB from DX.
Alrainbow
3,260
1,431
450
I don't know if they support the RAAT device inside THE DAC. in fact I'll bet they don't. The RAAT is network audio device for Roon alone to my understanding
wisnon
3,536
640
1,200
AL, he has a GG2, so no built in Ethernet.
I cant figure why he doesn't get DSD512. Only thing is that he has a separate DSD512 chipless engine and its not engaged. R2R DSD ONLY does up to 256.
wisnon
3,536
640
1,200
Azizz, please post a picture of your Dac, front and back.
EDIT: found the pictures here, https://www.whatsbestforum.com/threads/golden-gate-2-reactions.24388/page-4#post-513809
It seems you need to actively engage DSD512 chipless module. Not sure if that is pushing in the faceplate button, as that is usually to switch between USB and SPDIF input...I always had Vol CTL Lampis since B7 (you use the remote control), so am not sure how this is done on your Dac.
abeidrov
VIP Donor
Dec 17, 2015
706
341
443
Moscow
I checked it, when I ordered the dac, and was told, that the switching between chipless DSD512 and R2R is fully automatic in GG2.
wisnon
3,536
640
1,200
OK, Didn't know that.
Must be a software setup issue in Roon then. Not familiar with Roon. Al is better to help there.
Alrainbow
3,260
1,431
450
A question list
1- Does the antipodes have a usb output that you are using to convey your. ?
2- If so what formats / bit rates does or play ?
3- Can you play any dsd from Roon ?
4- when you play pcm a d dsd post a screen shot of the usb connection as it's seen in Roon .
Mr P
25
22
235
Fort Myers, Florida
Azizz - On your browser go to http://myantipodes.com. Click on the manage button. Click on settings and then on the Roon Ready icon. Make sure the DSD Support window has Native DSD selected and not DoP. I may be wrong, but I believe DoP only supports up to 256. The screenshots you posted in previous messages are identical to what I have. I have an older version of the Amanero firmware that only supports DoP up to 256. Hope this makes sense. Let me know the outcome.
Reactions: abeidrov
abeidrov
VIP Donor
Dec 17, 2015
706
341
443
Moscow
Thank you, I will try that, when I get home. I was sure, Lampizator dacs only support DSD via DoP, that is why I've always selected DoP.
abeidrov
VIP Donor
Dec 17, 2015
706
341
443
Moscow
It worked. I have DSD512 support now:). Although, I am not sure, I liked, what I heard.
Mr P, thank you very much!
wisnon
3,536
640
1,200
not at all. they support native. Dop cant support 512
abeidrov
VIP Donor
Dec 17, 2015
706
341
443
Moscow
I was just curious to try upsampling to DSD512. Beforehand, I briefly tried upsampling to DSD256, and redbook sounded really good. I can't say that it definitely sounded better, than native rate playback, but on some tracks I preferred it to native with 242 tubes.
Reactions: wisnon
audioquattr
307
413
280
Netherlands
Native rate playback beats upsampling...to me at least.
To me aswell very much!
Even upsampled PCM i find it hard to listen to.
Reactions: wisnon and bonzo75
Bobofei86
95
82
85
44
Hi Gents
I'm using RK242 and directly connect my GG2 to the ATC 50a active now, the tone is just right and i want to stay with the 242 tubes, however, due to the impedance mis-matching 1,600 ohm in GG2 and 10k ohm in ATC active, the bass and the overall picture is limited and im going to buy a preamp soon, since i have VC in my GG2, may i know the whats the best range of the sweet spot happens? Always heard that most of the preamp need to work well after 11o clock, may i know any particular range in GG2 is the best as well? E.g between -10db to -20db, i fully understand there are dependences of diff preamp and equipment for the best result, just want to hear the experience of the experts in this thread to share your VC setting. Thx so much, Joe
cpcat
161
189
175
South Carolina
I’m no expert - but I’d say when you get the new preamp, start with the vc in the GG2 bypassed (0db) and go from there - if you get any distortion then simply back the vc on the GG2 down until the distortion goes away.
when shopping for a pre- go for at least 40k input impedance single ended if possible (20k minimum) and one with high output capability so you are less likely to run into overload issues with the 242.
