O o-MJ-o New Member Apr 27, 2024 4 0 1 36 UAE Oct 20, 2024 #1 Hello, So I found this E280F tube swap options for the dacs in kassandra theead: E280F, E180F, E810F, 6j11p, D3A Currently a Valvo white label 280 is installed in the genus845, can these be swapped like the dac too? Thank you. Last edited: Oct 20, 2024
S Synaxis Well-Known Member Jan 3, 2024 944 1,674 168 USA Oct 20, 2024 #2 o-MJ-o said: Hello, So I found this 280 tube swap options for the dacs in kassandra theead: E280F, E180F, E810F, 6j11p, D3A Currently a Valvo white label 280 is installed in the genus845, can these be swapped like the dac too? Thank you. Click to expand... I will let Joshua from @Believe High Fidelity chime in, but I THINK on the Genus you can run the Elrog 284 tube in place of the 845. DON'T TAKE MY WORD FOR IT and wait until Josh or someone more of an expert can answer. Reactions: o-MJ-o
O o-MJ-o New Member Apr 27, 2024 4 0 1 36 UAE Oct 20, 2024 #3 Thanks, but only want to swap the smaller tubes not the 845.
S Synaxis Well-Known Member Jan 3, 2024 944 1,674 168 USA Oct 20, 2024 #4 o-MJ-o said: Thanks, but only want to swap the smaller tubes not the 845. Click to expand... Oh - sorry. I misread your post. Reactions: o-MJ-o
Believe High Fidelity [Industry Expert] Nov 19, 2015 1,807 525 450 Hutto TX ibelieveinhifi.com Oct 20, 2024 #5 o-MJ-o said: Hello, So I found this E280F tube swap options for the dacs in kassandra theead: E280F, E180F, E810F, 6j11p, D3A Currently a Valvo white label 280 is installed in the genus845, can these be swapped like the dac too? Thank you. Click to expand... Yes you can run the alternatives mentioned. Reactions: o-MJ-o
