I found the sound I was looking for in the NOS Telefunken (see post #34 in this thread). This tube pulled things together for me with the La Scala. While I still own the La Scala I rarely use it anymore, now putting my focus into the Lampizator Golden Atlantic TRP3.
There are many things I like about the TRP3 over the La Scala but of course it would be very difficult to list all of the nuances. Overall the TRP3 produces a much larger more pronounced presentation with fairly more detail.
The La Scala provides a great presentation but I’ve found that things sometimes become too congested if there is a lot going on in the music. The TRP3 provides better separation, clarity and depth in these situations. While the stage is generally somewhat larger I would say that the La Scala is close to equal when it comes to imaging but the TRP3 exceeds that with regard to stage depth.
The wide array of tubes that can be used with the TRP allows one to push past what the La Scala can offer and though frustrating in the beginning one can quickly learn which tube pairings offer the best results based upon specific genres of music or just their system in whole.
The TRP3 digs deeper in bass reproduction and produces high frequency information with a little more extension than that of the La Scala. It’s also possible to tweak the TRP to create more focus in the midrange or to accentuate more low end with tube rolling. It’s a versatile piece of gear!
I bought the La Scala DAC to go along with the La Diva transport. The sound from this combination is amazing. I compared the SPDIF connection to the I2S connection. No contest! The I2S connection is much better.
I also tried different types of Ethernet cables using the I2S connection. This also made a huge difference. I settled on an Audioquest Diamond Ethernet cable. I ordered an Ethernet cable from Aqua thinking Aqua would know how to make an excellent Ethernet cable. It’s been about a month and I haven’t received it yet. When I do receive it, I’ll post again about what I hear.
I also did some tube swapping. I listened to about a dozen different ECC81/12AT7 tubes. My two favorites by a large margin were the JJ ECC81 and the Mullard 10M. I slightly preferred the JJ ECC81. It was just a bit more nuanced. I also tried the Telefunken ECC801S. It was lush but not as nuanced as the JJ and the 10M. I think it is interesting to note that the JJ had a completely different plate structure from all the others.
Update: I received the Aqua Ethernet cable to use with the I2S format. I like it better than the Audio Quest Diamond. The Aqua Ethernet cable was more transparent and open, real nice improvement.
Wow, I am impressed that you tested the La Scala against the T+A 3100 HV generation and preferred the Aqua. Sure, the Aqua is the better value proposition, but I would have expected the T+A to come out on top.
The La Scala uses ECC81 type tubes, not ECC82. So you would need a Telefunken 801s. But I tested it and can´t recommend. It´s like the complete opposite of a Mullard ECC81.
If you like the Mullard CV4024 late military type, then try to get your hands on some older ECC81 Mullards from Blackburn. They have the same signature, but are in all aspects the better tube. Way better top end resolution while still being smooooth. If you can´t find Blackburns, you could also go for Heerlen Netherlands production - sometimes also found as Philips Miniwatt brand.
I was about to order and there are options for the tube. Balanced triode. Low noise and microphonics, etc.
Low noise and microphonics make sense but is “balanced triode” a consideration?
Thanks
Thanks
Yes- balanced should definitely be a requirement especially with new or NOS tubes. The tube used here is a dual triode- meaning two elements within the same package. In this case the circuit uses each side for a different function, unless they are running parallel then it would use both elements equally. Sometimes when purchasing used tubes you’ll see test results with different numbers, this reflects more or less wear for each element within the same tube. Sometimes this doesn’t matter if the numbers are in the higher range and will be used in parallel but if you’re relying on each for a different purpose within the circuit you’ll definitely want the elements to be as closely matched (or balanced) as possible.
I have an update regarding tube replacement in the La Scala.
After talking to Scott at Arcadia, he recommended Either the Genalex - Gold Lion, the Telefunken NOS or the Mullard.
The Teles were the “best” in his list followed by the GL’s and Mulliards.
I’ve ordered the Gold Lions as the “factory” La Scalas come with Reflecktor tubes and the Genalex are manufactured at the same factory and I felt more confident ordering them new and with matched triodes as well as low noise & microharmonics.
More updates coming.
Just done comparing two ECC801S with La Scala Telefunken and Siemens. I ended up with the Telefunken ECC801S - more neutral and precise. Both Siemens and this I heard significant improvement over stock Russian tubes. In past I have done tube rolling with CDP using 12AX7 tubes so I had a gut feel on what can be expected with top NOS tube upgrade and was not disappointed. The Siemens is lush and warm similar to stock so it is a great way to upgrade sonics while maintaining tonality. The Telefunken transforms the La Scala to a more neutral DAC while still maintaining a touch of midrange warmth. Happy with the results its like having two DACs, one lush and warm and the other neutral.
I've tried 10 different tubes in it and each had a nice difference.
In the end the Mazda's were my #1 choice with Amperex Holland being a close #2 if looking for musicality with an open, airy presentation with full pace.
