Sorry for not replying earlier. While Alnico is technically better than ferrite, you will find many Altec Alnico and ferrite sounding bad, and the occasional Altec Alnico and Ferrite sounding great. There are many who think TAD 4003 neodymium followed by TAD alnico 4001 are among the best drivers due to their Beryllium, and those who prefer other non-Be drivers to it.
There are too many field coil wannabes who never became western electric, not to mention many WE implementations outside Chueng's collection in Munich don't sound good.
So - similar to wood horns, metal horns, and composite material horns, try not to be focused on Alnico field coil only and listen to the speaker. Crossovers and matching drivers with horn design plays a big role
the Model 50 has a very high crossover, I can hear compression in violin and female vocals but the male vocals are better than AN-E as the midbass is better. Both AN E and Model 50 have a colour where recording stages sound similar across records, whether that is important to you or not I cannot say. Both are pleasant and you can listen long, though I don't find intensity in them.
With your room size, I would look at Devore O96, if you have higher budget than Audionec EVO 2, and above that hORNs Universum. If you like AN i would stay with it. But then if you like AN you might like Model 50. It is based on how you listen to recordings.
