Capacitor Question
Ron, I've been down the road I think you're headed down. A few things worth noting if you haven't yet - 1) measure the amp(s) input impedance, don't go solely by what the manufacturer states as you likely won't be able to return the caps. 2) First, purchase more modest priced caps as you might not get the integration you expect via your DIY first - pass. If it works, great, then buy the uber - expensive high - quality caps replacing the inexpensive ones.
Thank you. Getting the capacitor to achieve the crossover point and slope I want is a fair concern.
The integration is settled in theory, as I am simply trying to replicate the slope of the stock high-pass filter.
Also, instead of the in - line cap, you could try this which is what I'm about to do: https://www.wilsonaudio.com/products/activ/activxo
That device is an answer to a vastly more complicated question than the one I asked in the opening post. As a philosophical matter I don't believe in adding active components and risk adulterating the sound when I know the slope I want and a single capacitor will do the trick.
I'm curious to know of your results. I found the cap in series as part of a first order (with the amp input impedance as the resistive load) too gentle of a slope to be effective towards ameliorating my room modes and would've required a starting Freq rolloff too high for me to be comfortable with (6DB / octave).
I also agree that adding a component (Wilson ActiveXO) in the signal path is not preferred, but I'm willing to give it a try as it's not too costly and looks to be a very high - quality unit (included with the WAMM Master Chronosonic speakers) with flexibility far above a cap in series.
Again, curious to read about your results, I'll share mine too.
Ron, I am puzzled you got several inputs on how to solve this easily, yet you dismiss them as wandering off topic. Good luck with this
Respectfully, I do not understand what you are finding to be puzzling.
The opening post question is: Who makes a high quality high-end audio capacitor with values of 2,700pF and 3,000pF and some semblance of consistency?
I am grateful to everybody who suggested particular brands of capacitors. That answers my question. I thanked these respondents along the way.
Conversely I find suggestions of brands of active crossovers to be inapposite responses to my question.
Maybe the problem is that you do not really understand what needs to be done. People tried to help you. It is pointless to chase tight tolerance capacitors without checking (and if necessary adapting) the input resistance. And with the adaption of the input resistance you could even work with the tolerances given by Duelund without compromising the filter accuracy. Anyways I assume somebody gave you the idea that you need this, maybe this person should help you with your questions
The only "problem" I see here is that you seem to be trying to make up a problem when I don't have a problem.
Again, I thanked the people who read and kindly answered my actual question.
I don't consider looking for better than a 40% spread to be "chasing tight tolerance."
I understand that methodology. I measured the amplifier's actual input impedance.
This is an incorrect assumption. I am experimenting with relocating the high pass filter in front of the amplifier rather than after the amplifier on my own initiative.
Ralph Karsten kindly confirmed the approach I proposed on my own initiative, and confirmed my calculated capacitor value.
So why not go for the 5% very neutral Russian teflon caps from the Ukrainian vendor?
I'm not buying Russian these days.
From asking around apparently for these very low capacitance values there's not a lot of controversy about the sonic need for fancy capacitors. One friend recommends polypropylene. Jeff of Sonic Craft recommends RelCap RTE.
Once the fancy Duelund/Mundorf parameter is lifted, these capacitors are easy to find.
Thank you.
So all is solved, perfect, sorry for chiming and and making a fuss about nothing. Maybe it would have been helpful if you stated all the things you have checked before hand that could have shortened this thread. Good luck with this endeavor
Thank you very much for your help!
Thank you.
Actually you would support the Ukrainian but never mind
(...) From asking around apparently for these very low capacitance values there's not a lot of controversy about the sonic need for fancy capacitors. One friend recommends polypropylene. Jeff of Sonic Craft recommends RelCap RTE.
Thank you.
Well, the signal goes through these capacitors - they are in series with the input. If they do not matter, why would any other capacitor in our systems be relevant to sound quality?
I dislike the use the word "fancy" when applied to high-end components unless they come in a velvet lined box. ;) These brands have several class of components - your choice was "fancy", but surely Mundorf is not a "fancy" brand. They supply us with technical information, including measurements, and details about what we get from them.
Ron this is quite easy and your are correct it needn't be over complex.
I tried to articulate it here- your are applying a simple 1st order filter to the input of the amp:
This is not an active filter like @DasguteOhr suggests here:
https://www.whatsbestforum.com/threads/capacitor-question.41026/post-1061837
Here is a simple calculator- you can ignore the "L" for inductance, lets assume you want to filter to 80Hz on the input of your amp that has a 100K ohm input impedance
You would need a cap that is .019 mfd or nearest commercial value 0.022 is good enough for a first order filter
I found a discussion by the late Roger Modjeski on this exact topic that dispels the need for accurate 1% caps- btw Roger had no time for exotic capacitor material talk fwiw
link:
"A quick note on how to calculate crossover component values for 6 dB/octave filters.
C=1/6.3 x frequency x input impedance of amplifier (or thing following the filter). It's simple.
A customer requested a 600 Hz crossover at the input of an EM7 amp. Standard EM7 amps have 150K input impedance so the value would be 1.76 nanofarad (1760 pf). The closest standard value is .0018 uF. Anything from .0015 to .0022 would be fine. For gradual crossovers the value is not critical. The only place accurate (1%) capacitors are needed is in a RIAA network or an active filter. I find it amusing when neuoritoc audiophiles want to use a 1% capacitor where the value is approximate anyway. That's just plain silly.
:lol:
(more on this if you want)
:rotflmao:
He also asked about the RM-10 which has 100K input impedance. Most power amps are in the range from 15K to 150K ohms and you can usually check this by simply plugging an ohm meter into the input jack of the amplifier in question. If you get on OL on the meter or several meg ohms there is probably a capacitor in the input already and you have to get to the other side of that cap, measure the resistance and change that cap to the new value. That's all there is to it.
Any capacitor of any voltage will work fine. I would use a polypropylene or Mylar."
Good luck!
It has an active low-pass filter in front of the bass tower. You don't necessarily need a second one in front of the amp in the signal path. I've described how I would do it. Well, everyone can do it as they wish.
P.S
I like semi-active speakers. I do the same thing. Passive and active bass.
Why not go for silver mica capacitors? Tolerances are as low as 1-2%
I would stay away from silver mica. The tend to be “hard” sounding from my experience.
Thank you.
Cause those are horrible? Imho of course, but still.
Talking of Ukranians, Abbas makes wirewound caps in the same range for his phono... just an idea.
Capacitor choice is very much system and taste dependent, perhaps a set of at least 5 different pairs is the minimum required to make a choice that is not severely compromised.
The capacitors take a really long time to sound good—at least 200 hours. Most people lack the patience.;)and they are really big.
Hi Ron,
Duelund is doing nothing wrong. These values are pico small, and they aren't setup for that with the way they make capacitors. The fact they can offer it at all is sort of impressive. Sadly it would be expensive in a silly way to buy dozens to match. On that note cheap capacitor meters work fine in general - enough to measure cables accurately that are in the two digit PF range.
Most "audiophile" capacitors in circuits and not crossovers tend to sound like HiFi. There are not many I can approve of for sounding right in a general sense and mostly only in a specific circumstance sense. But the value you're looking at opens up doors for other types of capacitors. Here's two capacitors that will likely work just how you want and the tolerances are so tight that it's up to you if you want to measure out matching as it's unlikely to be appreciable in any way. 2700pf and 3000pf . The only note is to avoid excessive heating when soldering; normal soldering works fine but lots of short interval reworks is not advised.
These two caps are on my short list of cost-no-object choices for an inline corner filter or anywhere I can get away with such low values. Silver Mica are not my preference, unnatural, and unpleasant unless paired with a very soupy tube amplifier that needs all the help it can get. I literally only use Silver Micas out of desperation and over certain other ity bity caps that are worse (sadly this does happen where there are just no options but it's rarely critical to the sound).
If you're wanting other recommendations feel free to reach out.
I appreciate people trying to be helpful.
But I wondered how long it would take people to wander off the reservation into topics and suggestions which have only the slightest tangential relevance to the extremely specific question in the opening post.
It seems more like describing a syzygy than describing something tangential.
If the goal is DIY, then you need capacitors
if the goal is a high pass filter, then one can buy a pre-made product that does what they need/want.
I guess you’re saying the goal is the former?
You get an extra point for using “Off the reservation” on the 4th of July.
Using it on Columbus Day would also have worked.
Hi Ron,
I was sent a link to this thread.
Unsure if it is ok for me to write here. Apologies in advance.
Vacuum impregnated metal foil capacitors lend themselves badly to ultimate precision in small values.
That being said, we do have a dealer who ordered 0.0027uF and 0.0033uF values in bulk for CAST Cu-Sn 630v capacitors - they should be able to find a few that will be very close in value.
Best regards,
Frederik
