I spent 10mins with the exact same problem
i do find the air total unstable ,its logs out every 5 minute back to cable and the transporter
Mine does too, it is incredibly annoying.
I am not sure if I understand right what you wonna say. Devialet says that a running iTunes is and will still be needed for the Devialet.
Or are you talking about internet radio stuff only?!
That is exactly what I understood from the infos I had prior to Munichs High End. And that is why I was so surprised by other information here. We will see soon. New Devialets should be in the stores within some weeks.I doubt it will be a upnp streamer. From the sparse information we have Ethernet will use the same Air software. This new software emulates the presence of a soundcard, so anything which plays music through your computer speakers should also come through to the Devialet - in principle.
I am using Itunes 11.0.3 so there may be some issues according to the Devialet Website in the bitperfect solution but even if it is forced to 16/44 it is not stable.
I have moved since a long time to a cable solution (Audirvana and HiFace2) and the test with the new Air2 will not change it. Apparently there are some people who have been using Air without any interferences for some time when you read the forums (I mean the previous version) but all the people I know personally have also moved to a cable solution; I have lost any confidence in the reliability of the Air solution. I guess the best solution will be the upgrade with the Ethernet which should produce the same sound as the Air without interferences !
but I would need a stronger WiFi signal (currently ?57dBm) to trust this for regular use
What a mess. The best thing about owning a D-Premier, and justification for its price, has been that Devialet delivered on the claims for excellent performance that it advertised and that reviewers supported.
But the braggadocio and hyperbole promoting new products on the recent Devialet site was nervous-making. Somehow all the investor money that Devialet boasted about attracting has altered the clear sightedness of the company’s message.
On the technical side, update instructions are (when one can find them after infuriating circular traverse) incomplete or misleading. In the past, I have been able to use Air up to 24/96 without annoyance. Now the claimed Air2 high resolution streaming above 24/96 delivers crackle and rasp, and lower resolution playback is punctuated with momentary dropouts. I have a robust wifi signal, always at about -31dBm, in a Mac Mini music-dedicated system.
And why is there no statement about the upgrade benefits of firmware 6.0? Is there any sonic or operational improvement to the D-Premier? Or is it only for the benefit of the newly introduced products?
But I just received a lovely new Chord usb cable that DOES make a sonic improvement, so it's back to wired via Audirvana>Stello U3>AES/EBU>Devialet.
Has anyone downgraded their firmware?
Is it possible to go from 6.0 back to 5.7.x?
Have you tried any non-Itunes player ?
"...were I to suggest anything, I would say that the "dimensional presentation" of the music is better - of course, that could be my imaginary validation of something I want to feel is better - which is why, in part, we need input from Devialet."
Having set aside my disgruntlement about Air2 and given a listen to firmware 6.0 through a wired feed via Audirvana, I also hear a more, as you say, "dimensional presentation". I suspect we may not be delusional, since I listened through, captivated, to the end of a Beethoven symphony I intended to only sample for audition.
gm
