I have all of them and they are really good. Or let me clarify that... I have all of the AP and BN SACD files.
Got to wonder why the bulk of these DSD and non-DSD downloads are from artist that are dead or no longer record or perform or from material that is years gone by, is it easier to get the material ( masters etc..) if an artist is long gone or retired ? Just wondering as current "hi-rez" material ( non-classical) seems to be sparse ?
Wish Acoustic Sounds luck, maybe they can pull it off.
It was reported over at CA that the tagging was being done with AudioGate![]()
Wow, they spared no expense!
My sentiments exactly.
Because DSD is becoming more visible in the mainstream, I've seen mastering facilities say they "can work with DSD". Most of them usually buy a Korg or Tascam and call it good. This is not, to me anyway, the correct way to master and handle DSD. Channel, Five/Four, Mirror Sound and others have spent tens of thousands of dollars and hundreds of hours learning the software and the intricacies of the DSD format. These are the people that I would want to master my material.
Bruce do any of these "people" you note actually sell material for download ? just asking. As I would rather have it done the right way than some smoke and mirror process.
personally; I have around 3-4 terabytes of dsd files and listen to them all the time. I also listen to PCM hirez too. if you get a chance to enjoy some dsd downloads you will get hooked easily. I can listen to them all day long....they sound analog to my ears relative to the very nice PCM files which are not quite as analog and real sounding in comparison.
I see this event as a watershed moment in the expansion of server based dsd listening.
Anyone have any recommendations of titles on this site?
"64 times the resolution of compact discs"...
"Salina, Kan., music retailer is the first to offer Direct Stream Digital music downloads"
Missed that one by almost two years. But, nether-the-less, raising the viability of DSD and downloads to the great unwashed.
2L has been offering these for some time now I beleive.
