The emoticons on this forum are very low resolution.I thought you were smiling.![]()
I think a good thread would be the best subs with the Magico Q5 - i bet it would not differ too much from the M5. I know that Goodwin Audio likes to run them with the JL Audio F212. I might try that at some point, again, my issue against subs is about intruding on my neighbor one floor down.
It would be great news for me as I already have the twin subs. Maybe one more per my buddy Frantz and I would be very happy.
You may recall the thread I started, asking for commentary on the different approaches taken by Geddes and Harmon/Welti toward multiple sub placement. While the Geddes approach does require a minimum of 3, he also states that with 3 subs only 1 is placed in the front corner, not 2 as you currently have. As such, to adopt the Geddes approach you'd have to move one of your subs to a position probably mid way on the opposite side wall, then the 3d sub probably would go somewhere behind the row of couches. With the Harmon/Welti approach, you'd leave your 2 subs where they are, then add two more, one for each rear corner. Your room is large enough to go with either approach.It would be great news for me as I already have the twin subs. Maybe one more per my buddy Frantz and I would be very happy.
Steve,It would be great news for me as I already have the twin subs. Maybe one more per my buddy Frantz and I would be very happy.
I cross at 43 Hz. Remember I run my X-2's full range and use the subs to bring up the bottom end. IOW I am crossing out everything above 43 Hz
brian
You asked a question in the thread about multiple subs and how many? I will answer it some in this one. You mention you had a problem at 65 Hz. First the Geddes approach does not preclude the use of different subwoofers ... They, of course need to be quality subs and with variable controls for phase, level and crossover points. I believe you are currently using JL Audio subs. The third sub in this configuration does not need t be very powerful as it is used to "fill" the holes in the FR. An image if you will.
As an experiment I would suggest to find a third sub. Leaving EVERYTHING as is presently in the system, i-e the two other subs where they are and the way they are set. You can borrow a sub from your friendly dealer, a lesser/smaller one from the JL Audio line will do. Small enough so that you can place it on the side wall on a chair for the duration of the experience. Set the crossover to something like 50 Hz and start measuring while varying the phase and the level control. You should hear very little from the subs even when close to it. You need some help and you must have a way to measure your response.
This is unusual for audiophile and 2-ch but try it and you may find that nasty problem to just disappear and your system overall sound improved by a respectable margin...No "bass response" only. Even the midrange appears clearer when the bass is properly reproduced ... Takes a while but IMO worth it.. If you like what you hear, the cost t of this vast improvement which is real, FAR from subtle both measurably and audibly, is minimal ...
