Mike, I appreciate your comment and consideration but to be clear, I would never consider my system to be "world class" without DSP. Believe me, I have tried everyway I know to make it sound just good (forget "world class") with an analogue crossover but just can't do it. To begin, when using separate subs that are typically located behind the mid/hi towers, one simply cannot overcome the physics of the timing error that is inherent using such an approach. In such a system, if you cannot delay your Towers by several msecs, you have no chance of getting a seamless sound whereby sounds from both driver systems arrive at the ear at about the same time. Secondly, due to the use of discordant drivers in the subs and mains, the use of lower slope analogue crossovers augments this problem with a resultant sonic overhang and smearing around the crossover point that is just not sonically acceptable. It should of course be said that these are problems that may also occur in a multi-driver full range system such as big Wilsons, Magico, Focal, etc, but in those cases, the speaker designer is dealing with drivers that are generally emanating sound from approximately the same physical space. This is a huge advantage for the engineer designing an effective crossover in such systems. When a system has subs that are say, 4 ft behind the Towers, the challenges of designing a good crossover change dramatically. Without DSP, I just can't get there and I'm not sure I have ever heard a system that could under the conditions I have described (i.e. separate sub located behind the mains with the crossover in the 80-100Hz range.) As far as EQing the room for boundary effects, I certainly might be able to solve some issues with a good analogue parametric equalizer, but the refinements offered by a good DSP unit allow for adjustments with far greater precision and refinements, all of which adds to the system's overall attributes if one can really dial-in the system effectively. And therein lies the rub. I wish it was easier said than done, but until I change speakers, DSP will likely remain with me for quite a while. I really do hope someone comes up with an easier way to implement really good DSP. I really don't get it. We put a man on the moon and we cracked the human genome. Can't we just buy a piece of gear that has a big label on the front panel that says "push here, and your system will sound like you are sitting dead center in row M of Symphony Hall in Boston". Oh well, I guess hope springs eternal! But the bottom line is that like all other engineering solutions, there are plusses and minuses (not "right" or wrong"). In exchange for adding an additional circuit that processes my signal, I derive benefits that for me, provide a net sonic gain that is far more rewarding with DSP than without.. I strongly believe that if I owned different speakers, I may feel differently. But for now, in my current system, its the best way I know to render unamplified sound reproduction with a reasonable facsimile to what I hope the original music sounded like in it's recorded space, or in the case of electronic or amplified music, in the producer's head..
