The one I use is this one: http://www.isoteksystems.com/cgi-bin/products.pl?id=17
One of the tracks is a "Rapid Rejuvenator" that is a great 3-minute pick-up.
Thanks - so where a system takes an hour to burn in, how much would this be? And at how much DB do you have to play it, can you play it at low volumes?
Hi, is there any file I can run through a dac for a quick burn in of the system every time I come home?
Also does this work to burn in new speakers or amps as well?
The first time you play the disk it should be at normal listening levels whereas subsequently it is played at a level where you can carry out a conversation. He claims just a 6 hour burn in is required
Hi what about daily burn in, to warm valves and drivers, which normally takes about an hour? Can that be sped up, by playing only one track or some pink noise?
(...) . Warm up and burn in are two very different things
Not to sound promotional, but feel free to give this one a try:
http://www.taralabs.com/cascade-noise-burn-in
