Frank, since you are visiting after many days, take a look at this room...unfortunately in Utah http://www.whatsbestforum.com/showt...stening-Room-1&p=283672&viewfull=1#post283672
Hi Frank, Jack and Manolis point them straight, but at this dealer in Paris http://www.whatsbestforum.com/showt...integrated-amp&p=309925&viewfull=1#post309925 , I got to listen to them pointed inwards as well as straight. He prefers inwards, I preferred straight. It wasn't for the roll off, it was for the soundstage, things got deeper and a bit more in-between. I don't think your room will allow that though, as the sound would hit the speakers in front first.
Ah when I was at Jack's my recollection was that they were pointed at the listening seat, thanks for that.
Yep toeing my Animas out more would mean the Epilogs would maybe intrude more, but sound is a pressure fluctuation in air so it can't hit anything, maybe being a bit pedantic here...
Frank Hi , I didnt realise you had the phantoms as well,comparing tethered systems must be interesting ?
I have two pairs ,sometimes three in one of my room sit isn't ideal.
Keith.
yes possibly at home, at hifi shows where there is more space he points them out - or maybe because Manolis is there too they do that
Are the three presentations very different, I guess the Phantoms and Epilogues are more or less full range, although you are using similar amplification in/for all three loudspeakers.
Keith.
If you are referring to Bonzo's pictures of my listening room I take offence
If there is anything strewn on the floor it is the odd LP sleeve or CD case and whilst untidy at least I don't have any big flat surfaces reflecting sound.
Fast food detritus is unlikely since I detest fast food.
I learned at least 20 years ago that the most important part of a hifi is the room, and where the speakers are in it. I gave up audiophilia at about the same time, hardly ever change kit but listen several hours per day since I retired.
I am not a very "visual" person so clutter doesn't bother me at all, but IME a cluttered room always sounds better than a plain one.
It may well be that not having the Epilogs where they are would help the Animas, but the Epilogs are probably still the best speakers I have heard so I'm keeping them and they sound best where they are.
I don't come here often but did today since I wanted to see if Bonzo posted anything about Italy.
BTW I am also a fan of the Goldmund Apologues, which the Epilogs superseded and the Analogs too.
Keith.
That does make rather a large difference Ked, depending upon programme.Lol, so Anima sounds different because it is not full range? Well played.
That's interesting ,presumably a conscious decision by the designer, it isn't unusual to roll off the top a little is it, LV I believe do the same .The Animas are much more rolled off in the treble than either the Epilogs or the Phantoms, even though I have now set the mid and treble controls level (the standard is with some attenuation of each) which gives a more even balance between bass and mid in my room and a bit more sparkle.
The Phantom frequency balance is quite similar to the Epilogs but not as refined with less pure musical timbre.
Amusingly one guy who has been here to listen preferred the Phantoms to the Animas, the Epilogs more again but the price difference is a bit steep the Epilog 1&2 were about €130,000 last time I looked.
Keith.
Anyone mounted on the ceiling?
Will start with three, yes diffusion can be used on the floor, just as can be used on the ceiling. Lot easier to put on floor though I guess.
Before I get accosted by the retentive masses, I know these most likely scatter rather than diffuse strictly speaking. All I want is better focus and sense of space. Already use wooden devices that scatter behind my rack.
Well I consider them full range
I haven't seen any measurements for them ,perhaps Frank has measured them?Well I consider them full range
Do you find the presentation of the sound to be very different?
Keith.
