Our Newest Video! -- "The Jaguar Guide to Buying Vinyl"
Jaguar
221
17
1,575
Bellevue, WA
This segment is targeted at those just getting into vinyl. The project has turned into a 3-part vinyl video series, starting with Jaguar Turntable Setup, now Buying Vinyl and Part 3, my "50 Best Pressings", which is coming around January and I expect the one this crowd will be most interested in. In the meantime you can let me know what I missed in Part 2, which I'll be adding to the notes on the blog page.
Filming only took about 3 hours, since I got smart and bought a teleprompter. Nothing like video to show you how not good at talking you are, but overall it turned out OK. The audio ended up with too much echo, because I made the mistake of only using a mini shotgun mic; I improved it a bit in editing, but I should have used a lav mic. Feel free to leave your suggestions to make the next one better.
[video=vimeo;191863249]https://vimeo.com/192029136[/video]
Hi-FiGuy
2,241
763
385
All my approved vinyl gets outer sleeves.
If you have issues sliding them in and out, turn the outer sleeve so the opening is up.
Jaguar
221
17
1,575
Bellevue, WA
HFG, obviously it gets down to personal preference, but the reason I don't recommend this is because, if you turn the outer sleeve sideways you either have to take the sleeve off every time you play the record or you have to turn the entire album sideways and can't read the spine...otherwise they slide off all the time. Half of my albums are worth less than $50 and I don't care that much about the covers, but even if I did, sliding the album in and out once in a while doesn't have much effect on the cover, in my opinion (and I'm quite fussy about my stuff). Thanks for watching the video.
XV-1
3,620
2,633
1,860
Sydney
And that's a problem? :D You have to pull the cardboard lyric sheet and the actual record out of the sleeve - I find the 1 additional second removing the protective outer sleeve no big deal personally.
all part of the joy of vinyl and looking after your precious records, no matter how much they are worth.
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
On the outer sleeve suggestion I prefer having the opening facing up. The inner gets inserted behind the jacket with the opening facing sideways. I can read the spine just fine and there is no sliding of the outer sleeve that way. I'm slowly adding both inner and outer sleeves to the majority (about 75%) of my records.
With regard to proper shipping, the record being outside of the sleeve does not add rigidity in any way, so I don't know how you came to that conclusion. You should still do it however, and you do so to prevent seam/ede splits from possibly occurring during shipping. Even though an LP mailer's content may be properly packaged (cardboard liners at the very least) and secure (tight) there will always be some movement which can cause seam/edge splits.
Cool video though and I'm sure those new to vinyl will appreciate the effort you put into it.
Hi-FiGuy
2,241
763
385
I appreciate the videos you are making, have been watching them as they pop up.
Am I correct you are an online only business, I don't see a B&M location?
My thought behind shipping outside the cover has always been to save the cover edges from being torn by the record through rough handling by the PO/UPS/FEDEX.
Jaguar
221
17
1,575
Bellevue, WA
Good point Johnny. This is what I did with my valuable albums. I got rid of them on the covers that are already beat up or I don't care about, but my main goal something like this, where I don't have to deal with them. This is the kind of suggestion I need to add in the notes.
Jaguar
221
17
1,575
Bellevue, WA
Yes HFG, avoiding cover splitting is the reason for shipping the album outside the cover; I got that mixed up in my notes.
With regard to Jaguar, I work online with clients around the world, but I also have a listening space in Bellevue (there’s a video of the Jaguar Listening Space also on the Jaguar Blog). My local clients come by all the time to hear products in the Jaguar system and pick up products. However, I hope the videos will be a good way to get to know people who can’t make an easy trip to Seattle.
