I'll ask you again - do you agree with his contention about such behaviour of the clock timings?
I am not following Don's argument. I am following yours and they continue to show errors. Bigly.
I will sum up your position and mine:
1. You are relying on what you think you have heard in sighted tests with strong bias ("good clock must sound better"). Even if you changed nothing, you would be hearing such improvements. So there is no basis here in scientific investigation.
2. You are then working backward, convincing yourself that there must be a difference here between digital and analog. Everything you say are your words, not presented in any paper, research, references, etc. Outside of that you are ignoring the fact that analog jitter is tons, tons higher than digital. So even if your argument was right, which it is not, you still have no explanation for why heaps of speed errors in analog at low frequencies is inaudible to people
3. Psychoacoustics completely backs what I explain. None of yours follows the same.
Bottom line is this: you can believe *subjectively* that better clock sounds better to you. And other people for that matter. That is perfectly fine. It is no different than folks claiming improvements for much lesser devices.
What you can't do is say audio science backs any of this. No audio science will accept your sighted, biased tests as the basis of anything. So you need to dispense with all of this technical talk. You can't be a part-time vegetarian.
If it is too uncomfortable for you to distance yourself from audio science, then you need to take audio science seriously. Start with proper testing protocols. Present that data. Let us repeat it. And then we can go on.
Alternatively adopt subjectivity fully and be done with it. Talk about free radicals this, and molecule alignment that, and you will be golden. Same number of folks will buy your gear that do with the kind of talk you have been presenting.
