ZYX Ultimate Dynamic
SMKL
75
I have been toying around with the thought of getting a ZYX Ultimate Dynamic as my Ultimate Omega will be mounted onto nether turnable. My SUT with 20x and 40x gain should be sufficient to cope with the 0.15mV.
Can anyone share their experience with this cartridge? Does it sound similar to the Ultimate Omega? At times I find the Ultimate Omega a tad too detailed and jarring.
Many thanks in advance.
Cheers,
SM
Interesting, I own the Ultimate Omega (low output/silver) and I find it a very polite and velvety sounding cartridge, detailed enough with very healthy mids and bass.
Haven’t heard the Ultimate Dynamic, but have considered it before going for the Omega. Its low output made me choose the Omega (even-though I have a capable phono preamp to support it).
Haven’t heard the Ultimate Dynamic, but have considered it before going for the Omega. It’s low output made me choose the Omega (even-though I have a capable phono preamp to support it).
Hi Axel, my apologies for not drawing a reference. I was actually comparing it to my Koetsu Rosewood signature when I made that comment. On its own, the Ultimate Omega is a very capable cartridge and that’s itself was a replacement for the Premium Omega that I had previously. The Ultimate Omega is a massive improvement over the previous Premium Omega and is a very “real’ sounding cartridge especially with vocals as they just appear to be there with the correct ‘mouth’ size. Imaging is perfect. I do like the ZYX for Jazz, large scale classical etc hence I have been a loyal fan and am now considering an upgrade to the Ultimate Dynamic. The new construction of the engine in the Dynamic intrigues me to give it a shot.
Best wishes,
SM
Best wishes,
SM
Thanks SM!
Actually my second cartridge is a Koetsu Urushi Blue Sky, which is very different from the ZYX. It’s less open and has more mid and mid-bass density, less low bass extension. But both are very easy on the ear.
Thanks SM!
Actually my second cartridge is a Koetsu Urushi Blue Sky, which is very different from the ZYX. It’s less open and has more mid and mid-bass density, less low basd extension. But both are very easy on the ear.
But which is the best ZYX?
Ultimate Dynamic,Ultimate Diamond,Universe premium?
I never understood
I never understood
+1!
How do any of these newer-listed .24 mV models differ in sound from the UNIverse Premium?
I never understood
Apparently the Universe is only made for a particular dealer and it’s not available elsewhere. It’s now an obsolete model if I am not wrong but please enlighten me otherwise.
The new Ultimate series use their new designs whilst the Ultimate Dyna,Oct has a totally new topology. The ZYX website is a bit misleading as it shows the Ultimate Dynamic to be the top of the line cartridge with the Ultimate Diamond below it. I guess it’s true to some extent as the Ultimate Dynamic is a new design whilst the Ultimate Diamond is the top of the line for the Ultimate series based on the new Ultimate engine. The Diamond costs at least 2x the Ultimate Dynamic.
I never understood
Have you politely asked Tang to try?
+1!
I haven’t had the chance to have a back to back comparison. The only time I listened to the Universe was mounted on a Kronos with a full range of Cello equipment. Pretty impressive.
Main concern with the Ultimate Dynamic is the 0.15mV output. If it eventuates, I would have to use the 40x gain setting on my SUT to make it work. I quite like the soundstage and presentation from a lower output source.
I know I want a UNIverse Premium X-SB2.
I do not want a diamond or a carbon fibre cantilever.
Not sure if it is in production anymore Ron. AFAIK it is replaced by the Ultimate which has same output and only slight changes over the Premium
Why not??
Because the UNIverse Premium model is the one I know I like. How can I assume that I like a cartridge I have never heard more than one which I have heard several times and I know I like?
To me, new is not necessarily an improvement. To me, different is not necessarily better.
A carbon fibre or diamond cantilever probably means “more resolution” and “more neutral” and “greater extension at the frequency extremes.” Those differences, to me, are not necessarily consonant with naturalness and easier suspension of disbelief.
The fact is that I have consistently preferred components which do not go too far in those sonic directions. (Although the system I am planning to hatch goes a lot further in those directions than my prior system which I had for 18 years.)
The fact is that I have consistently preferred components which do not go to far in those sonic directions. (Although the system I am planning to hatch goes a lot further in those directions than my prior system which I had for 18 years.)
Ok, fair enough. However, without actually hearing a CF or diamond cantilever in your own system ( once it is up and running) and then comparing to your prior reference, I'm not so sure I agree with you. Many times in this hobby, the newer technology is in fact superior to what has occurred before. Not always, but many times. Kind of like saying that one likes the MM cartridge because that's what one is used to and has worked so well in the past..and with the systems of the past; the newfangled MC isn't going to be to my liking because it has possibly too much resolution. Hey,your choice, your money.
I agree with you. All I am trying to convey is that I cannot know in advance that I will like the new one more.
I spoke today with Mehran of Sora Sound.
1) Mehran says that the UNIverse Premium was only for the North American market. This is why it was never on the global ZYX website.
2) The UNIverse Premium currently is still in production.
3) The UNIverse Premium is the last boron cantilever cartridge ZYX will make.
