Tube rolling for an ARC SP-9 MKii
curiousjim
21
1
68
60 miles from a big city.
Just got this thing and the PO put in Electro-Harmonix EH6922's. They are not the gold pinned ones, they're the cheapies. Anyway, does anyone have some recomendations on other 6922/6DJ8 tubes I should try and why?
Are there any other mods you guys have done?
Thanks in advance for any thoughts.
JD
JD
I used to sell a DAC with 6922's on the outputs. The only tube I would use is the Siemens CCA grey-plate. About $350-450 a pair and worth it. Very fast and clean sounding. Look for them on ebay:
https://www.ebay.com/itm/2x-CCa-SIEMENS-tubes-GREY-shields-premium-6299-E88CC-CCa/282963936334?hash=item41e1f7044e:g:I6sAAOSwnVZashot
Steve N.
I have had excellent results with NOS 6h23 otherwise the lower noise Dutch production Philips / Amperex are also great.
Steve N.
Thanks for the link Steve N.
I’ll add them to the list. If I buy the CCa tubes and some Golden lions, it will just about double what I have in the preamp! LOL
Also looking at Harma, Amperex and Mullard.
One cool thing about this preamp, is the TT and the line circuits are separate, so I can see what works best for each.
JD
