Hi, all, my first post on your excellent forum, on which I've been lurking for the last few months. The below is humbly submitted, with apologies for a long-ish, perhaps tedious "what's better?" post. I'm inching my way into to the high-end, and am betting a lot of folks on here have been where I am now. Thanks in advance for any thoughts!
I recently moved into a loft apartment. A classic loft, completely open, no walls, 13-foot ceilings, 1500 sq feet. My living area/listening area is about half of that. Before I moved in, I worried that it would be an echoing, reverberant mess. But it's actually not too bad. The ceilings, which are barreled, have some kind of textured treatment, which seems to help a lot. I've also got a number of GIK Acoustics panels up, and the furniture, curtains, bookshelves, and record shelves help, too. I'm waiting on a wool shag rug to be delivered.
I've been running Klipsch Forte IIIs, and they sound... not bad! They struggle, however, in the lower octaves--perhaps not surprising--but they can produce some good volume otherwise. I temporarily hooked up my HT sub--a basic 12" SVS--and it improved the bass response considerably.
I'm now considering a pair of Rhythmik 15" subs, to be run stereo (XLR) from my ARC preamp. I think these will really fill out what the Fortes can't do in this room. Rhythmik actually suggested two 18" (!) subs, but I think that might be a bigger pair of boxes than I want to deal with.
I've also considered REL, but they're maybe pricier than I want to go. I'm leaning toward Rhythmik for 1) their good rep 2) their value over other, dealer-distributed brands and 3) they don't use DSP in their amps. (I'd like to keep my chain all-analog.)
I'm mostly bouncing this plan off the group, but also would love to hear thoughts about other speakers that play well in big rooms, as I'm considering upgrading from the Fortes. (I probably will keep the Fortes as a secondary pair though.) I figure I'll be in this loft for about two or three years, and, well, what better time (not to mention Covid hi-fi madness) to mess around with some stupidly large speakers! I'm considering the following. Budget is up to $10K. New or used.
--Klipsch La Scala: Perhaps the natural upgrade path from Fortes. (Though there seem to be some out there who would have it vice versa.) I've seen some new La Scala B-stock and a fair number of restorations/rebuilds out there. Hard to know about the workmanship in the latter.... Note: I've not heard the La Scala, but I like the Klipsch sound generally. I don't quite have the corners for K-Horns, unfortunately.
--Magnepan 3.7i: A very different approach than the Fortes, obv. I heard a pair of Maggies--Timpani's, I think--a few years back; blew me away. I've got the space, could be a great time to own a pair. Q: A dealer (not of Magnepan) told me that panel speakers don't play well in large rooms. True? False?
--Focal Kanta No 3: I heard a pair of Sopra No 3 that really impressed me. They're a little out of reach, budget-wise, but I think I can get that great, Be tweeter and imaging in the Kanta.
--Magico S3 (used): They're certainly in the higher-end of the budget. I'd have to stretch. I demoed a pair and was impressed by the silky, controlled top end, but maybe a little unmoved by what I heard as a slightly restrained feeling. I often find that I have an emotional response to my Fortes--despite them being obviously less refined--and I might miss that in something like the Magico. Or maybe not. Maybe it was a so-so demo.
--B&W 802 (used): I think these can be had readily on the used market. The super speakers of ten, fifteen years ago? Again, I'm definitely not opposed to used.
--Harbeth: Maybe 40.1's? Harbeth are a big question mark for me, as I think big floor-standers will do best in my room. But a lot of people's whose tastes I dig on this forum use Harbeth.
I listen to all genres, though prioritize small-group jazz. I'm not buying for just that genre though. I'll be looking at new power amps (perhaps a Parasound JC5 or ARC Ref 75SE) at some point. I currently run the Forte's off a pair of Schiit Aegir. I'm well aware that most of the above speakers will want more power.
Here in Chicago, I can demo a lot of stuff and have been doing just that. But obviously my room is going to sound a lot different than most dealers' show rooms.
Anyway, would love to hear some feedback on my plan to add the Rhytmik subs, plus any thoughts/suggestions on good speakers to fill this big-ass room that might be a solid upgrade from my Forte's. Thanks, all.
Analog: Garrard 401 with Artisan Fidelity stainless platter and bearing / Technics SP-10 MK2 / GrooveMaster 12-J and Jelco 850L and 850M arms / SPU #1E, Koetsu Black Goldline, and AT ART-9 carts
Digital: Schiit Yggy DAC / BlueSound Node 2i streamer
Pre: ARC Reference 40 / ModWright PH 9.0 phono stage
Power: Schiit Aegir (x2) / Quicksilver SET Mono (x2) / AES (Cary) SE-1 300B
Speakers: Klipsch Forte III
Interconnects: Blue Jeans Cables
