SET amp owners thread
bonzo75
22,650
13,685
2,710
London
Who's that is looking beautiful
Reactions: gian60
bonzo75
22,650
13,685
2,710
London
Reactions: gian60
audioquattr
307
413
280
Netherlands
morricab
9,532
5,070
1,228
Switzerland
Some past and present SET/horn gear. Will post a few more later :)
Reactions: christoph
morricab
9,532
5,070
1,228
Switzerland
Our show from 2017. Don't have an equivalent video from this year. This speaker is one size smaller than our main demo speaker and one size larger than our new Monitor 10SL IMG_0016.jpg IMG_0018.jpg
bonzo75
22,650
13,685
2,710
London
What is this speaker? This runs on SETs? What db and impedance?
Reactions: gian60
CGabriel
618
92
265
WA, USA
www.shunyata.com
Caelin
when did you get the horns
These are from the Pure Audio Project
These are easy to build open baffel kits
There are several models
This is the “Quintet” model which has quad 15” woofers and a Horn for the mid-tweet.
Very efficient and easy impedance.
Can be driven easily with a 300B 8 watts.
I plan to try bi-amp with a First Watt crossover and running dual 2A3 amps. Will be interesting. Also am building a layered bamboo baffel for them.
bonzo75
22,650
13,685
2,710
London
Which 2a3 amps
morricab
9,532
5,070
1,228
Switzerland
Dynamikks Monitor 10SL, 93db, 8 ohm nominal, 6 ohm minimum.
bonzo75
22,650
13,685
2,710
London
This is all passive? Half active is active from what frequency
morricab
9,532
5,070
1,228
Switzerland
The one in the video is the Monitor 10.15 and it is 96db fully passive (can also be made half active) with 8 ohm (min around 5-6 ohms) impedance. All Dynamikks are SET friendly.
morricab
9,532
5,070
1,228
Switzerland
yes 93 db all passive. The main driver is a coax with 8 inch paper/carbon fiber mid and polyester sandwich compression tweeter. Horn comes in a bit over 1Khz
Reactions: bonzo75
christoph
4,689
4,077
825
Principality of Liechtenstein
I really like the look of this room. Could you add a custom W bass bin with a couple of 15” vintage drivers as a subwoofer for the total system? That is basically same recipe as what Kevin did historically. Quite cheap to make if you felt so inclined or buy a cabinet and add your own drivers / crossover.
The room where this System resides atm is really quite small.
How big would such a W bass bin be? I have seen the "original" bass Support from LV and it is really huge :rolleyes:
Do you happen to have a building plan and know what Drivers to use for such a monster?
Reactions: Audiophile Bill
