Rogoz Audio. Reasonable pricing and flexible design.
https://www.rogoz-audio.com/en/products/audio-stands.html
They look well made, but I don't like their models with an upright in the middle as that is where you need to access connectors and switches at the back of components. It looks kind of stylish, but is functionally a design flaw imho.Rogoz Audio. Reasonable pricing and flexible design.
So you're basically saying you're an audiophile Jack?! I found a good solution using upgraded FE Cerabase Classic feet on my Taoc racks. I can't recall how long they took me to level, but it was probably too long, lol. My Dealer who is Russian would have done it in <5 mins!4 post racks can be a relative PAIN to level perfectly. Even if many tables now can be leveled independently, including motor and/or arm pods, the OCD in me just has me belly on the floor adjusting spike height LOL. I'm using a 4 leg now. It's fine now that I got it leveled but on my belly you can bet I was wishing I went with the three poster LOL I would have been done in less than ten minutes, instead of the hour and some it took me.
I use 3 Stillpoints U6's under my cdp for the same reason.Hi Bodhi
There is one application where I like 3 legged racks however, Turntables They are so much easier to level
Tima, the problem is that last para. There is no such rack that is "specifically designed for that purpose" and does not affect sound possibly negatively, or at least we do not know which to select without trying all the recommendations mentioned in this thread. And once he picks a wrong rack, he is stuck unless, as you say, he gets lucky. With footers he can make his own luck because they are easy to shift in and out and and match to personal taste and requirement.
Dear Ron. Dont listen to him too much. Regard 51% of his comments as noises or hum. If you havebudget, just by any stable decent ones like CMS, SRA, Nothing rack, whatever give you peace of mind. They may or may not improve sound but I dont think they will do any harm.So then the answer is to get a seemingly sturdy, well-made, decent-looking rack, and then foot to taste.
Tang
Tang
