Lamm's with Stealth cables
5,474
2,890
I can borrow a full loom of Stealth cables (Dream Royal and Sakra) to listen with the Lamm's. Does any one have experience with such pairing?
I thought you moved on from the Lamms and CJs? Care to give us an update on where you are at with electronics for the XLF?
Still listening to the cj's, Lamm's and VTL's. Any of them pleases me in the XLF, but cable matching between the ML3 or M1.2R has been an issue.
I listen Stealth Indra V 10 in my system
I was not very impressed
Sound transparent and little light and not dynamic
Sakra sure will be better
Have used Lamm amplification for 19 years and frankly I haven't found anything (so far) I prefer to Stealth Sakra with my Lamm L1.1 Signature/ Lamm ML3 Signature. Used them when I had ML2s, ML2.2s, LL2 Deluxe and L2 Reference. Still use a couple of Indras for CD replay, but in my system quite a bit behind the Sakra in my opinion.
Not so enthusiastic about Stealth speaker cable though. Speakers are Sonus faber Stradivari - speaker cable is Kimber Kable Select KS 6068 and am presently trying out single runs of Yter speaker cable (so far pretty fine) and will probably try three runs which has been recommended to me to try..
Can I ask what speakers you are using? My main concern was the speaker cable.
